Old 08-28-2013, 07:26 PM   #1
Organism_ike
Centrifugal Advance Sticking
I've been through 2 different GM mechanical advance spring and weight kits so far, and can't seem to get any to work! With this accel kit I've been using recently, every time I tighten the rotor down completely (which is just until the bolt head contacts the rotor and I feel resistance), the mechanical advance just sticks. I can force it forward without effort using my hand, but it won't spring back unless I give it a push. All I have to do is back both the rotor screw back a couple turns and the advance springs back smoothly again.
On another note, the $15 accel kit I bought was advertised to make 24 degrees at 3000 rpms. With light springs I make 4 degrees at around 2500 rpms, and with one light one medium I make about 8 degrees at 4000. At least the $5 summit kit I had before actually worked... (tired of Chinese crap metal)
What kit should I buy to just get the timing over with? I'm tired of the problems that come with saving money. I just want 24 degrees at 3000 rpms.
1983 Chevy C10 LWB
305 SBC bored .030 with cast dished pistons
Summit RV Camshaft 204/214 .424/.444
416 Iron Heads
Performer Intake, Quadrajet, and Flowtech Long Tubes
TH350 2.73 10 Bolt
Organism_ike is offline   Reply With Quote
Old 08-28-2013, 08:50 PM   #2
geezer#99
geezer#99's Avatar
Re: Centrifugal Advance Sticking
Might find your answer in here.
http://www.crankshaftcoalition.com/w...EI_distributor
Old 08-28-2013, 09:42 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
The stock hei weights are just fine. Just Change the springs really. What are you trying to accomplish? Trying to limit max advance? Get timing in sooner?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-29-2013, 12:16 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
be sure the plastic bits on the post are not worn,and the weights holes are not oblonged/egg shaped
I had a rusty friction area,caused me probs and had an oily goo sticking advance in the can as well ,gave up and replaced the dizzy all at once
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
