Old 08-29-2013, 12:35 PM   #1
69StepsideMedic
Bagged with stock floor and inner fenders
Does anyone have any pictures of c10s on air with stock arms and trailing arms with a bolt in notch and inner fenders with 16 inch steel wheels ..... Or something similar?
69StepsideMedic is offline   Reply With Quote
Old 08-29-2013, 08:51 PM   #2
cubber
Re: Bagged with stock floor and inner fenders
If you use a notch, your bed won't clear the rear differential when aired out. I have 17" steelies, and 2.5" drop spindles.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 08-29-2013, 08:55 PM   #3
69StepsideMedic
Truck looks awesome .... Do you have a bolt in notch at all ? Got another picture from the side ?
Old 08-31-2013, 06:02 PM   #4
RaceAGMC
RaceAGMC's Avatar
And you're running stock inner fenders?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 08-31-2013, 06:38 PM   #5
cubber
I have the Porterbuilt bolt in notch. My bed floor is slightly raised. My stock inner fenders are out right now because I'm painting them, but they do clear. Tire height is crucial. Mine are 27" tall. Here is a side pic.
=MATTHEW
Old 07-12-2015, 09:48 PM   #6
jondancer
Anyone else?
jondancer is offline   Reply With Quote
Old 07-14-2015, 08:50 PM   #7
Mikeeal33
Mikeeal33's Avatar
1972 Driver SOLD
Mikeeal33 is offline   Reply With Quote
Old 07-14-2015, 09:20 PM   #8
TypeSL2
I am running the same wheels as cubber. I am on air, 2.5" drop spindles, no notch just yet. Going to put my notch in next week, but here is how it sits right now. I'm also going to install 2" drop blocks in the rear to help even out bag pressures.
James
TypeSL2 is offline   Reply With Quote
Old 07-15-2015, 09:30 AM   #9
andrewmp6
Cubber what rims are those?
Old 07-15-2015, 10:44 AM   #10
TypeSL2
Scratch that. I thought they were the same as mine, but I am seeing a stepped lip now. Maybe one of the Summit wheels?
James
Old 07-15-2015, 09:26 PM   #11
andrewmp6
A few aftermarket companies make rims that style was wondering how he got the center caps to fit.
Old 07-16-2015, 06:51 AM   #12
stevencvn72
Kill Bill...et
stevencvn72's Avatar
As said previously. As long as overall tire diameter is roughly 27", you'll be solid. Inner fenders installed, bolt in notch, bed raised 2" Crossmember sits on the ground as the tires rest on inner fenders.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 07-17-2015, 03:42 AM   #13
Mikeeal33
Mikeeal33's Avatar
DANG that's a beautiful truck.
1972 Driver SOLD
Old 07-20-2015, 07:34 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
This is as low as you can go with out cutting the bed out. N2billet did modify the inner bed sides, but the tubs are stock.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-20-2015, 08:42 PM   #15
jondancer
Man that's a nice truck
Old 07-22-2015, 09:27 PM   #16
big_al_71
big_al_71's Avatar
Stock inner fenders bed floor and small cnoth this is the lowest you can go with 20's all around
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-05-2015, 04:01 PM   #17
1972yuma
This is great information, what wheel width and offset are you guys running on your wheels? And are your tires tucking inside the fenders or on the 1st couple of inches of the outside where it's flat?
1972yuma is offline   Reply With Quote
Old 10-06-2015, 12:16 AM   #18
DLW
This is about as low as it can go on mine. Stock inner fenders with about 1/2" clearance at top, stock bed height with 1/4" clearance at top of diff., 20" wheels, 28.7" tall tires, porterbuilt bolt in c-notches, porterbuilt mild drop member with 2" drop spindles.
If I raised the bed a bit, the back could drop another 1.5", and remove the inner fenders would probably get another 1.5-2" drop. Don't have any new pics yet with the hood and bumper on, but they are on..
DLW is offline   Reply With Quote
Old 10-06-2015, 12:58 AM   #19
1972yuma
Beautiful truck! I really like the pro touring style. Thanks for the info. Are you bagged?
Old 10-06-2015, 01:47 PM   #20
DLW
Thanks. I am bagged at all 4 corners.
Old 10-27-2015, 08:19 AM   #21
Coursey
Coursey's Avatar
What bump stops are you using?
Coursey is offline   Reply With Quote
Old 10-27-2015, 09:43 AM   #22
DLW
Rear bump stops came with c-notches, for the front I have QA1 shocks and the bumps slide on the shock piston, just cut to length you want.
Old 10-27-2015, 01:38 PM   #23
Coursey
Coursey's Avatar
DO you have a part number for the shock style bump stop? I like that idea.
