Old 08-09-2013, 08:17 PM   #276
DURG
DURG's Avatar
Re: DURG's Black 65 C10
Decided to just do a couple short 90 degree tips on the end of the exhaust dumps. Installed the Lokar shifter bracket and shifter. I am going to cut a new hole in the hump where the shifter is now which is behind the OG hole the standard 4 speed shifter came through. I will weld a flush patch there and use a Lokar billet round boot ring and black "leather" boot.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 08-09-2013, 08:52 PM   #277
mooseknuckles
mooseknuckles's Avatar
looks good....is that the tranny mount style shifter?....how long is the handle?
mooseknuckles is offline   Reply With Quote
Old 08-09-2013, 08:55 PM   #278
DURG
DURG's Avatar
Yes. 16" I believe.
Old 08-12-2013, 09:31 AM   #279
BigJoe29
BigJoe29's Avatar
ok yeah i have to tag this thread, that truck is amazing
Aerodynamics are for people who can’t build engines. – Enzo Ferrari
- 64 Chevy C10 SWB- 440 BBC, Pro touring build in progress SLOWLY
- 73 Camaro LT RS- Pro touring build eventually
- 71 Bronco- my dirt monkey and current focus
The military doesn't pay nearly what it should
BigJoe29 is offline   Reply With Quote
Old 08-12-2013, 10:38 AM   #280
coulter
coulter's Avatar
killer lookin work man!!!
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 08-22-2013, 08:25 PM   #281
DURG
DURG's Avatar
I did a few more things on the truck and then took it apart in anticipation of final welding, grinding, and re-sandblast so I can get some paint on the frame and gear up for final assembly. These pictures may not be in perfect order and possibly some of the same stuff I have posted before but I took some over the past week and today so I will post them anyway. I have installed the bracket that holds the gas pedal studs, cut a rectangular hole for a larger Lokar boot and ring, and installed a couple braces back from the driveshaft loop/cross member back to a plate on the inner frame where the 4 link front mount attaches. This cross member and brace is removable even though it should never need to be. I put a couple more pictures of the discontinued Porterbuilt hood hinge relocation brackets I attached my front bracing to also. I took a picture of a deluxe wheel installed on the Ididit column and also a small gusset I welded in where I notched the cross member support where I relieved it for steering column clearance.
Old 08-22-2013, 08:27 PM   #282
DURG
DURG's Avatar
Old 08-22-2013, 08:32 PM   #283
DURG
DURG's Avatar
Motor is out and everything is off the frame in front too. I just need to take out the 4 bolts and the cab will be off and I can move the frame around in finish prepping for black paint.
Old 08-23-2013, 05:48 AM   #284
northern 85
northern 85's Avatar
Great.clean work!
northern 85 is offline   Reply With Quote
Old 08-29-2013, 06:48 PM   #285
DURG
DURG's Avatar
This thing is officially blown apart for final welding, grinding, blasting, and paint on the frame and suspension. Greg at Extreme Powder Coating has offered me a killer deal on powder for the suspension stuff but I think the shipping kills the deal. def going black on the frame for sure. Probably charcoalish gray on suspension stuff.
Old 08-29-2013, 07:16 PM   #286
likaroc13
Rollin' Old Skool
Cool! Look forward to seeing it reassembled & looking purdy
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 08-30-2013, 09:14 AM   #287
timmytimm3
Looks awesome! Are you still going to do more bracing in the middle of the frame or did you decide against it? I'm still trying to figure out what I'm going to do. We boxed the frame on my Father's 57 but that was all weld in stuff (fatman IFS, no limit 4 link). There are a lot of different opinions regarding boxing and/or bracing.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 08-30-2013, 10:04 AM   #288
DURG
DURG's Avatar
I decided this is the only bracing I am installing. I just wanted to tie in a little support where the 4 link brackets mount and figure the cab will tie in the middle good enough. I am running poly cab mount bushings. My bed also has multiple 2x3" rectangular tubing cross sills now instead of the channel type stock ones and angle iron bracing for the wood floor and everything is welded to the actual box sheet metal too. This will be bolted solid to the frame mounts with 1/2" bolts so that will stiffen it up some too.
Old 08-30-2013, 07:38 PM   #289
coulter
coulter's Avatar
killer work man!!! the extra bracing looks awesome
Old 08-31-2013, 11:22 AM   #290
DURG
DURG's Avatar
Frame welding and blasting done. Forward progress from here on out !
Old 08-31-2013, 12:22 PM   #291
Spragg
Nice build. Look forward to seeing the end result.
Spragg is offline   Reply With Quote
Old 09-01-2013, 10:40 AM   #292
DURG
DURG's Avatar
Got some black on the frame this morning.
Old 09-01-2013, 11:49 AM   #293
lolife99
67-72 parts collector,…
lolife99's Avatar
POR-15 or paint?
Keith
Convert to disc brakes.
Old 09-01-2013, 12:32 PM   #294
likaroc13
Rollin' Old Skool
Looks nice!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 09-01-2013, 12:35 PM   #295
DURG
DURG's Avatar
POR-15 or paint?
It's gloss black paint. Tractor Supply has an equipment paint for tractors and stuff. I did use POR-15 on my Impala. Just figured this paint would be fine on the frame.
Old 09-02-2013, 07:42 AM   #296
northern 85
All your pics are gone, that sucks!
Old 09-02-2013, 08:00 AM   #297
DURG
DURG's Avatar
Yeah, I have so many pictures on here and Chevy Talk I exceeded my free bandwidth. I had to upgrade my Photobucket account. The pictures are back now.
Old 09-02-2013, 10:24 AM   #298
DURG
DURG's Avatar
Hung a few parts and painted upper a arms and mid cross member.
Old 09-03-2013, 04:27 AM   #299
northern 85
Wow that looks fantastic!
Old 09-03-2013, 03:31 PM   #300
Low Elco
Glad to see it looks that BLOODY GORGEOUS! I have a gallon of it with hardener on the shelf, just a-waitin'!
Low Elco is offline   Reply With Quote
