08-30-2013, 06:39 PM | #1 |
Shock question
I was wondering what the best shock to use on my 69 swb step side.
I am using air bags with a 2 1/2" drop spindles and in need of enough travel When aired up and down? Thanks steppside69 Posted via Mobile Device
69 chevy stepside (project) 2006 Silverado Z71 Ext. cab 2005 Saturn VUE (wifes dd) |
08-30-2013, 10:06 PM | #2 |
Re: Shock question
Have you thought about getting shock relocators? With the shock relocators I believe you can use the factory shocks and not compromise ride quality for a shock that doesn't have enough travel in it to properly compress.
Scott |
08-30-2013, 11:24 PM | #3 | |
Re: Shock question
I would use a drop shock if I KNEW they researched the pressure, travel, & stroke required. From what I've found, most use a shock that only meets the dimensions/mounts & put their p/n-stamp (sticker) on it.
08-31-2013, 02:22 PM | #4 |
Re: Shock question
Thanks for the replies, has anyone made there own shock relocators? I wouldn't think it would take to much to make. Or are there possible problems if I move the shock higher than the existing hole? Thanks again
08-31-2013, 07:38 PM | #5 | |
Re: Shock question
On my CC dually, I will likely purchase pre-fabbed rear brackets/mounts that weld to the rear end if I can find them in the correct dimensions. If they aren't made in the dimensions I need, I'll build them too....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-31-2013 at 07:49 PM. |
09-02-2013, 12:07 AM | #6 |
Re: Shock question
Ok been doing research, whats the best/cheapest front shock relocator? In your oppinion?
09-03-2013, 10:00 PM | #7 |
Re: Shock question
I been researching allso made my own for the rear and made a big diff. in ride now I need to do the front.
http://67-72chevytrucks.com/vboard/s...d.php?t=418095
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
09-06-2013, 05:09 AM | #8 |
Re: Shock question
I made my own mounts from the factory mounts I cut off my stock rear axle. Shocks are Monroe Matic for the rear of a 1980 Jeep CJ-7. I have since upgraded to Monroe Gas-Magnum. I use the same part # front and rear.
09-09-2013, 07:12 PM | #9 |
Re: Shock question
Thanks for the info
09-10-2013, 02:22 AM | #10 |
Re: Shock question
Ekstensive in Houston. I believe are $25 for the front ones
Posted via Mobile Device |
