Old 08-30-2013, 09:54 PM   #1
danno76
headers
what headers do i need for my 70 c-10 2wd v8 ??anyone have a part number for a cheep header that WILL CLEAR MY CLUTCH LINKAGE ?? im tired of tryin used ones that hit the linkage or the lower a frame
danno76 is offline   Reply With Quote
Old 08-30-2013, 10:07 PM   #2
scott-wisc
scott-wisc's Avatar
Re: headers
I just ordered #69892 Hedman Hedders. Won't know if they'll fit for a few weeks.
scott-wisc is offline   Reply With Quote
Old 08-30-2013, 10:53 PM   #3
SS Tim
SS Tim's Avatar
Re: headers
Might do better if we knew a few things.
Big block or small block?
Factory V8 or converted I6?
Are the engine stands in the forward V8 position?
Is the clutch linkage V8?
What are you using that hits?
SS Tim is offline   Reply With Quote
Old 08-31-2013, 07:05 AM   #4
danno76
Re: headers
everything factory its a 350
Old 09-01-2013, 09:31 AM   #5
Re: headers
All I know is the rear tube has to drop down vertical,if not angled slightly forward. You may still have a clearance issue going under,but passing in front is the main issue. The headers that have a vertical tube generally have a sharp bend at the bottom taking the tube straight back. The only issue going under,with some headers,will be the lower z-bar arm if it's in the path of the tube. I have had to cut that arm off and re-weld to one side. It's no big deal. Others have move the frame mount rearward for headers that dropped down too far back to clear the tube.
Old 09-01-2013, 06:44 PM   #6
Z10
Z10's Avatar
Re: headers
Check out Sanderson CC11.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 09-01-2013, 07:44 PM   #7
Flint70step
Flint70step's Avatar
Re: headers
I made a custom Z-bar by cutting it in three equal sections.Then moved the center section reward to clear the #7 header tube.I moved it back to where the front of the center section was lined up with the back of the two outer sections.Cut some 3/16 plate and welded it up.Now it looks like a rod journal on a crank shaft and it cleared the primary tube.I'm not using it anymore,I'll find it and post a pic
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 09-01-2013, 07:58 PM   #8
jd7
jd7's Avatar
Re: headers
The Sanderson C11 header is the cleanest,but the Headman 69640 will work as well just not as pretty
jd7 is offline   Reply With Quote
