#201 |
Re: Camaro Caliper Brackets
i would like to get a set of these made if there arint any allredey if you stell makeing them
#202 |
60-66 Nut
I don't have any ready to ship right this moment, but I have the parts for them. I'll send you a PM with payment info.
#203 |
can I tuck tractor wheels?
any of these ready for sale?
My build page.... http://67-72chevytrucks.com/vboard/s...d.php?t=347666 |
#204 |
60-66 Nut
I'll have to take a look tomorrow to see how many I have at the shop. If I don't have enough, I can just order some more parts laser cut. Are you wanting bare steel or powder coated?
#205 |
what size is the bolt that holds on the brake hose?
thanks |
#206 |
60-66 Nut
The banjo bolt should be 10mm.
#207 |
#208 |
![]() Join Date: Jun 2007
Request PM sent
#209 |
60-66 Nut
PM replied to
#210 |
Moderator
![]() Join Date: May 2007
I am confused. I went to the boneyard today to source/price all the parts to use with these brackets. I did not find any 94-97 Camaros with rear disc brakes....all of them were drum?? Were rear discs an option on these years? I did run across a 99 Camaro that had rear disc brakes, but did not pull the trigger because of the years you specified here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#211 | |
60-66 Nut
Rear disc brakes were not standard equipment on the '93-'97 F-bodies. I believe they were typically found on the Z28's. The '99 Camaro has a different caliper and rotor than the '93-'97's.
#212 |
Still plays with trucks
The 93-97 Camaro used very small single piston front calipers. I wouldn't use it. The fluid volume is probably too little to work properly with a larger D52 front caliper in a 4-wheel disc application. Look at the 98-2002 Camaro master cylinder instead. They used dual piston calipers up front with much more piston area so the fluid volume would be more appropriate.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#213 | |
The 98-up stuff was on all the cars V-6 or V-8. Same for the front brakes. The rear on them uses an internal drum brake inside the brake rotor for the parking brake so the calipers are different with no provision for a mechanical parking brake in them. The rotor thickness is different too so they would need spacers to work on the thinner rotors the kit is designed around.
#214 |
60-66 Nut
Good info 68 TT
Thanks for posting ![]()
#215 |
Received my brackets for the 93-97 Camaro brakes and they look great! Question about proportioning valve. I am replacing my M/C and Proportioning valve due to prior leakage. I bought a new M/C for 78 corvette and wonder if I should buy the proportioning valve for the same, go with stock proportioning valve or I did find one on ebay that says it will work for 67-87 trucks disk disk although they refused to answer my question when I asked if it would work for this application. If anyone else has done this swap with sucess input would be appreciated. Thanks
#216 |
60-66 Nut
You can try the Vette prop valve, but you may or may not be happy with the brake bias. Anymore I recommend the Wilwood #260-11179. It already has an adjustable valve in the rear circuit, so you can adjust the rear brakes to how you like them.
#217 |
I need a set and P.M. sent
Posted via Mobile Device |
#218 |
60-66 Nut
PM replied to
#219 | |
425hp409
![]() Join Date: Oct 2008
1. Combination valve - I used the factory 68 brake light switch, no proportioning valve and no metering valve. No metering valve needed with 4 wheel disc, and so far works great with no proportioning valve. I installed a master cylinder for 4 wheel disc so as not to have a residual check valve in the outlet of the master cylinder, which is only used on drum brakes. My truck started out as a 4 wheel drum and I had previously installed 72 disc brakes. 2. Parking Brake - My truck is a short bed, however the long and short bed trucks use the same rear cables, so my method should work for all trucks. I was able to use the Camaro factory rear parking brake cables and the factory Chevy intermediate cable. I moved the intermediate cable from the trailing arms to the inside of the frame, connecting to the Camaro cables. I fabricated new brackets for the front of the rear cables and made links to take the slack out of the intermediate cable. The photos show how I did it.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette Last edited by 425HP409; 08-31-2013 at 11:16 PM. |
#220 | |
425hp409
Page two of photos
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
#221 |
60-66 Nut
Thank you Charles for posting this info along with those well detailed pics.
#222 |
Iv'e read all 9 pgs. Of this post,and it looks like you don't make a set of these for a 14 bolt rearend 77 c-10. Please advise thanks
#223 |
60-66 Nut
That is correct. I do not make any rear disc brackets for either of the 14 bolts. That 14 bolt is not original to your '77 C10. A '77 C20 would have a 10.5" FF 14 bolt, but a '77 C10 would have a 12 bolt.
#224 |
thanks did not know that I think i'll be looking for a 12 bolt rearend first thankyou
#225 |
Captainfab, I'll take a set. I will send you a PM is a minute. Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
