Old 09-01-2013, 01:44 PM   #1
Gene Zick
Smile squealing fan
I have a 1961 chevy apache pickup with a 350 in it. The fan belt squeals all the time on start up. I have replaced all belts, have used belt dressing, checked pulley aligment but to no avail. I took it to a chevy dealer. They said they fixed it, but it hasn't changed anything. Any ideas about why it squeals?
Gene Zick is offline   Reply With Quote
Old 09-01-2013, 02:18 PM   #2
63burban
Chevy addict
Re: squealing fan
Your pulleys may be really worn and the belt is no longer riding on the sides but the bottom of the pulleys.
63burban is offline   Reply With Quote
Old 09-01-2013, 05:34 PM   #3
jtrichard
Re: squealing fan
welcome gene.... can you put up some pics of the belts and fan?
jtrichard is offline   Reply With Quote
Old 09-02-2013, 07:24 PM   #4
Gene Zick
Re: squealing fan
Attached is a view of the fan belt/ pulleys. I think the belts are riding on the shpulders of the pulley not bottoming out.
Old 09-02-2013, 08:01 PM   #5
luvbowties
luvbowties's Avatar
Smile Re: squealing fan
Gene, can u move the ps belt forward to another pair of pulleys? And do you have "good" belts, like Dayton, Dayco, Gates, Gatorbacks etc.--NOT the "discout-store-brand"? The latter often squeal regardless of how tightly they are adjusted; which reminds us: belts must be adjusted properly.
Sam
luvbowties is offline   Reply With Quote
Old 09-02-2013, 10:21 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Re: squealing fan
Another thought might be to remove one of the belts and then the other, and run the engine to determine which one is squealing. While that belt is off operate either the water pump or power steering pump by hand to see if there is excessive resistance on either one. Perhaps one or the other has a bad bearing or other problem.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-03-2013, 01:20 AM   #7
jtrichard
Re: squealing fan
since your squealing is on start up i would say its the alternator as its on the right side and as the engine turns it pulls on the fan and slacks the belt on the alternator ... try taking the wires off the alt. then start it and see if if it stills squeals and use a good quality like gates green stripe ect.
Old 09-04-2013, 06:55 PM   #8
Gene Zick
The belts are made by GM. They are labeled GM extreme.
Old 09-04-2013, 08:44 PM   #9
jtrichard
Re: squealing fan
i have 63 c60 with 396 in it and had to go with dual belt to the alt. and fan to get the fan to turn and not slip all the time it is a big fan and the alt is on the drivers side so the slack would be on the fan yours the slack is on the alt.(pass side)
Old 09-04-2013, 10:58 PM   #10
63burban
Chevy addict
Re: squealing fan
Yup, clutch fans take a lot of power on start up. The belt looks low on the water pump pulley, might be slipping. Loosen the belt, try to turn the pulley while holding the belt and see if it slips.
Old 09-05-2013, 08:48 AM   #11
luvbowties
luvbowties's Avatar
If your alternator is suspicious and it has enough adjustment left, try a longer alter. belt so it gives more of its pulley-surface-to-belt contact area. The greater the arc segment touching the belt, the better the belt grip.
Sam...see, we are not giving up!
Old 09-07-2013, 11:09 AM   #12
Gene Zick
Bingo!! I went with a second belt on the fan/power steering side. Squealing has stopped. Imagine all the trouble I went through step by step checking everything out including taking it to a chevrolet dealer [they couldn't fix it] and it turns out a $10.00 belt does the trick. Thanks guys for all your input. Happy days are here again!
