09-01-2013, 06:10 PM | #1 |
Wiring Question
Alright my Back right brake lights don't show up and neither do the back Red side-markers..As I was looking under my truck I noticed a Red wire looked like it had been cut off
Help please !!!
1971 GMC Sierra 1959 GMC 100 |
09-01-2013, 07:43 PM | #2 |
Re: Wiring Question
No red wires were used on the rear lights. There is a four wire flat harness going from the front to the rear lights. Light green: backup lights, dark green: right rear turn signal, brown: park lights, tag light, and trim light, yellow: left rear turn signal.
Brake lights work through the turnsignal circuits. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-02-2013, 08:45 AM | #3 |
Re: Wiring Question
check too make sure the rear light assembly has a good ground.
check inside where the bulb goes too make sure the contacs for the bulb are present and not broken off. i like too use a long wire that has alligator clips. one side goes too the battery ground. take the lens off the light and sand/scrap a clean bare spot of metal on the light houseing. touch/clip the wire too the spot and test your light. if it works you'll need to take the two screws out that are next too the bulb and clean up the spot around the two screws where the back of inner light houseing touches/mounts too the bed. this is where the ground is. of course you should have a test light. with it you can check the bulb socket too see if it even getting juice.if its not then you need too keep testing the wire. the rear harness has connectors too the lights in the rear bed sides pull them apart an test.(if you do this they prolly should be cleaned up an greased anyway. still nothing? in the last frame crossmember theres round plug with the four wires that go through the metal. pull the rubber peices apart an test from here also.(jim pointed out witch wires too test) if all else fails buy some new bulbs
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
09-02-2013, 09:02 AM | #4 | |
Re: Wiring Question
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
09-02-2013, 09:05 AM | #5 |
67-72 parts collector,…
Re: Wiring Question
Any time you can post pics with your questions,... it would be very helpful.
09-02-2013, 09:24 AM | #6 |
Re: Wiring Question
Alright I will today, I dont have anyway of getting the fuses out ?
09-02-2013, 10:05 AM | #7 |
Re: Wiring Question
They usually pry right out...use something non metallic...if they have been in there for 40 years they may be a little sticky, but the are just held in by thin metal tabs squeezing the fuse ends.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives Last edited by slow-1; 09-02-2013 at 10:12 AM. |
09-02-2013, 10:13 AM | #8 |
Re: Wiring Question
But what if they break in there ?
09-02-2013, 10:18 AM | #9 |
Re: Wiring Question
Pull out the ends with needle nose pliers and put in a new one.
09-02-2013, 02:17 PM | #10 |
Re: Wiring Question
Oh ok well that was simple, how do I know if my points are bad ?? It wants to start but it won't' and it cut off while driving it on me
09-02-2013, 02:24 PM | #11 |
2WD Jimmy
Re: Wiring Question
Your points are probably fine. Check/replace your fuel filter.
09-02-2013, 02:26 PM | #12 | ||
"I ain't nobody, dork."
Re: Wiring Question
Lots of old trucks have messed up rear lighting because of prior owners hacking up the rear harnesses to wire in trailer lights and such. I've had to rewire the entire rear ends of trucks because of it.
Gary
09-02-2013, 02:30 PM | #13 |
Re: Wiring Question
I just put a new fuel filter in there,,I wonder
09-02-2013, 07:07 PM | #14 |
2WD Jimmy
Re: Wiring Question
