12-05-2003, 03:51 PM | #1 |
What year did they change to the wider rear axles?
I curious when they changed from the shorter rear end(67-68) to the wider rear end (69?-72?)
I have the 68 stock rear end. Is there a wider rear end that will still have the trailing arm mounts? thanks
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
12-05-2003, 03:59 PM | #2 |
its all about the +6 inches
Some where in the 1970 model they went to a wider rear. That would still be a 6 lug. In 71, they went to 5 lug.
So a mid 70 - 72 would be the width you're looking for and maintian the coil set up. |
12-05-2003, 04:00 PM | #3 |
Low & Slow
I'm not sure on this but I think it is 64-69 and then 70-72. Don't quote me on that but I think 70 was the first year of the wider axle.
70' C-10 LWB Fleetside 4.5/6 drop |
12-05-2003, 06:25 PM | #4 |
Keepin an eye out
Sometime during the 1970 model year..some are narrow and some are wide. Mine happened to be wide
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
12-05-2003, 06:34 PM | #5 |
Broke
I've wondered the same thing, because my 72 3/4 ton 4x4 had a narrow rear end.
72CheyenneSuper1ton4x4BigBlock |
12-05-2003, 06:57 PM | #6 |
So is it possible to have a wider, five-lug, coil-spring rear-end?
Also, does anybody know how much wider they are from flange-to-flange? thanks
12-05-2003, 07:45 PM | #7 |
Designated A-hole!
1.5 inches is what I have heard.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-05-2003, 09:17 PM | #8 | |
Yes, you will be looking for a 71-72 1/2 ton coil sprung rear end.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
12-05-2003, 11:44 PM | #9 | |
Bram
12-06-2003, 12:54 AM | #10 |
casey do not use wheel spacers they are unsafe they put the whole load on the wheel studs instead of on the hub where it belongs.. you could try a different backspacing on the wheels instead
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-06-2003, 04:16 AM | #11 |
I agree it will put alittle more load on the bearings, but I don't 4x4 or carry any load, and if you think about it what would be the differance between an adaptor moving the wheel out 1" or a back space on the rim moving the wheel out 1", then you can't rotate the tires from front to back, what do you think?
12-06-2003, 05:37 AM | #12 |
Your right. You will impose the same load on the bearing no matter how you space out your wheel. It will change the load on your studs. Can't say if it would be bad. There's only one way to find out.
