Old 09-03-2013, 12:37 PM   #1
mlevario99
Exclamation Delphi 56 Series Connectors
Does any one knows where I can buy these kind of connectors, I am looking for the 6 connectors, I was able to find the female plug, but I need the male plug. I am trying to wire the whole truck and I want to use the same kind of plugs.
Here is a picture of the male plug
Here is the female plug from my truck
Thank you for your help
mlevario99 is offline   Reply With Quote
Old 09-03-2013, 12:44 PM   #2
64fleetside
Re: Delphi 56 Series Connectors
Standard brand hp7110 and hp7120-about 5 terminal each pack.
64fleetside is offline   Reply With Quote
Old 09-03-2013, 01:14 PM   #3
mlevario99
Thanks 64fleetside, I am doing a search and having trouble finding them, do you have a website where they sell them.
Thanks again.
Old 09-03-2013, 01:40 PM   #4
T Smith
T Smith's Avatar
You can reuse the housing and replace the terminals?
http://www.pcsconnectors.com/packard56.aspx
T Smith is offline   Reply With Quote
Old 09-03-2013, 01:44 PM   #5
mlevario99
Thanks T Smith, I try that webpage but they do not have the male connection, they only have the female connection
Old 09-03-2013, 01:51 PM   #6
ChevyJr
Junior Member
ChevyJr's Avatar
Napa auto carries them. They're listed as Wire Terminal/OE Terminal
part number: NW 725447
ChevyJr is offline   Reply With Quote
Old 09-03-2013, 01:58 PM   #7
mlevario99
chevyJr, thanks, that is the actual metal connector, I am looking for the actual plastic enclosure, I am sorry for not been specific that it was the plastic plug.
Old 09-03-2013, 03:08 PM   #8
Gary V
Active Member
Gary V's Avatar
If you don't mind not using the factory terminal configuration. Check out this link. You can buy both sides for a 6 pretty cheap.
http://www.waytekwire.com/wps/portal...P&mfg=45&sc=19
Gary V is offline   Reply With Quote
Old 09-03-2013, 05:24 PM   #9
Snailed
Snailed's Avatar
American Autowire had them in their classic update kits. Maybe they would sell you just the plastic shells.
Snailed is offline   Reply With Quote
Old 09-04-2013, 01:29 AM   #10
Captainfab
60-66 Nut
Have you checked here?
http://www.texasindustrialelectric.c..._terminals.asp
