Old 09-03-2013, 01:29 PM   #1
kaphillips
kaphillips's Avatar
th350 to th400 with 70 factory tilt whell question
I have a 1970 cst with factory tilt wheel that am going to be chaging the th350 to a th 400. My question is if I use an original th400 from 70 truck with all related truck shift linkage, replace the indicator on the column as for a th400 will the indicator line up correctly and the column have the extra travel for the extra gear. Is the tilt column unique to the th350 and the th400?
kaphillips is offline   Reply With Quote
Old 09-03-2013, 01:32 PM   #2
Bigdav160
Bigdav160's Avatar
Re: th350 to th400 with 70 factory tilt whell question
Knowing GM, the column is the same.
BTW, TH350 and TH400 are both 3 speed transmissions
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-03-2013, 01:36 PM   #3
kaphillips
kaphillips's Avatar
Da my bad I was having a senior moment, yes of course they are both 3 speeds so nothing would need to be changed on the column and the indicator will match what gear I am in correctly?
Old 09-03-2013, 01:53 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Yes, correct. The linkage is slightly different however
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-03-2013, 02:26 PM   #5
cdowns
cdowns's Avatar
you need a different driveshaft
Old 09-03-2013, 07:50 PM   #6
BigRed76
BigRed76's Avatar
The indicator will line up correctly as long as the shift linkage is adjusted properly after you get the new trans in, it is sometimes over looked so just thought I'd throw that out there.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
