Old 09-04-2013, 04:32 PM   #51
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: Gulfcoast Build Updates (pics)
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 09-04-2013, 04:35 PM   #52
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device.
Old 09-04-2013, 05:36 PM   #53
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. I solved my steering coupling problem!! I cut off the original end coupler at the bottom of the steering column and cut a piece of tube and welded it to the end piece and drilled holes so I could attach it back to the bottom of steering column....
And I also rebuilt the original rag-joint with a kit from parts store, everything fits nice and tight plus my steering wheel setting level like it should, it was bout 1 inch sticking up more than it should have...
Posted via Mobile Device. Oh yeah I almost forgot I also deleted a section bout 1 1/2 inch off the bottom of the shaft....
Old 09-04-2013, 05:39 PM   #54
gulfcoast66
64-66 CHEVY JUNKIE
Old 09-05-2013, 08:51 AM   #55
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Here's one close.
Old 09-06-2013, 05:53 PM   #56
gulfcoast66
64-66 CHEVY JUNKIE
I got my Power Steering finally hooked-up!!!!
Thanks to a former board member Dreamer1 from the Square Bodies section hooking me up with a 1985 gear box and both hoses plus the fitting that goes behind the pump, Again Big Thanks Dreamer1....
The 85 hoses are a Great fit from the box across the frame to the pump...... I'm getting close to Breaking in that fat Cam....
Old 09-06-2013, 05:58 PM   #57
gulfcoast66
64-66 CHEVY JUNKIE
Old 09-09-2013, 11:12 PM   #58
gulfcoast66
64-66 CHEVY JUNKIE
Well last night I reworked my alt connector adding a resistor on the L side and a bigger gage wire to the S side of of the plug..
So now all I need to do is tie it in my harness which is already set up for a SI alternator, that's what I was running before I tore my engine down, this is for my CS alt..
Old 09-09-2013, 11:17 PM   #59
gulfcoast66
64-66 CHEVY JUNKIE
Old 09-09-2013, 11:19 PM   #60
gulfcoast66
64-66 CHEVY JUNKIE
Old 09-09-2013, 11:41 PM   #61
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Today I got my transmission cooler lines hooked-up and rad hoses installed.. tmrw I'm gone to tackle my harness..
Old 09-10-2013, 06:52 PM   #62
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Do anybody have any Pics of the Starter wire harness, from passenger side firewall connection down to starter.. ???? I need to see which wires go back to starter...
Old 09-10-2013, 06:54 PM   #63
gulfcoast66
64-66 CHEVY JUNKIE
Old 09-10-2013, 09:12 PM   #64
gulfcoast66
64-66 CHEVY JUNKIE
??? Anybody have pics of starter wired up.???
Old 10-31-2013, 04:54 PM   #65
gulfcoast66
64-66 CHEVY JUNKIE
Talking Re: Gulfcoast Build Updates (pics)
Well this Week while Iam home I tackled my hood I cleaned up all the rust on the front of the hood and I got a little down because I though I was not going to be able to use the hood, it was in bad shape ....
Anyways I know a lot of people don't agree with doing the bondo thing but until I can find a better hood this will have to do for now....
So the first thing I did was use a tiger paw sanding disk to remove all the rust and blisters, than I put three light coats of bondo sanding between coats, than I put some polyester topping on to smooth it all out, its not for a show truck just to get me back on the road....
I sprayed a good etching primer and sand that down than sprayed my top primer....again its something to get me back on the road....
Old 10-31-2013, 05:08 PM   #66
gulfcoast66
64-66 CHEVY JUNKIE
Pics.
Old 10-31-2013, 05:12 PM   #67
gulfcoast66
64-66 CHEVY JUNKIE
More...pics
Old 10-31-2013, 05:15 PM   #68
gulfcoast66
64-66 CHEVY JUNKIE
Some more...
Old 10-31-2013, 06:54 PM   #69
TJ's Chevy
TJ's Chevy's Avatar
Cool build!
Old 11-01-2013, 12:28 AM   #70
gulfcoast66
64-66 CHEVY JUNKIE
Originally Posted by T.J. MCCAULEY View Post
Cool build!
Thanks T.J. G.C.66..
Old 11-01-2013, 01:31 AM   #71
Captainfab
60-66 Nut
That turned out nice.....it'll be there for a while.
Old 11-01-2013, 01:43 AM   #72
gulfcoast66
64-66 CHEVY JUNKIE
Thanks Capt.. I hope so till I can find a rust free hood... I need to go to Arizona!!!!
Old 12-21-2013, 10:19 PM   #73
gulfcoast66
64-66 CHEVY JUNKIE
Yesterday I got to spend a little more time on my truck.. I was able to do something I been debating on for a while, filling the hole left from removing my gas tank from behind the seat.
Anyway I had some sheet metal left over from when I trimmed my inner fender to get my radiator to fit, I used a piece of that (3in round) to weld close the hole, I blew a couple of holes still trying to figure this MIG machine out... I topped it off with a Lil bondo and primer... Anyway I need more practice using a MIG machine.
Old 12-21-2013, 11:12 PM   #74
gulfcoast66
64-66 CHEVY JUNKIE
Pics
Old 12-21-2013, 11:14 PM   #75
gulfcoast66
64-66 CHEVY JUNKIE
One more...
