Old 09-05-2013, 10:48 PM   #1
rdrnation
Fuel doors on a short bed?
Why would there be these locking doors on a 69 gmc short bed? There is one on each side of the bed. The only gas tank on this truck is the one behind the seat.
rdrnation is offline   Reply With Quote
Old 09-05-2013, 11:02 PM   #2
Lee H
Lee H's Avatar
Re: Fuel doors on a short bed?
Well, not sure about your truck but my 72 SWB had these above the parting line, dealer installed auxiliary fuel tanks.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-05-2013, 11:07 PM   #3
In The Ten Ring
Some trucks had "saddle drums".......I wish my gas tank was not in the cab.
In The Ten Ring is offline   Reply With Quote
Old 09-05-2013, 11:08 PM   #4
rdrnation
there is no sign of a tank on either side. and the spid doesnt show aux tanks on it.
Old 09-05-2013, 11:14 PM   #5
Lee H
Lee H's Avatar
It was dealer installed so it would not be on the SPID. I don't think your doors are in the right position for dealer installed tanks. Maybe someone tried to install them some time in the last 40+ years.
Old 09-05-2013, 11:14 PM   #6
Lee H
Lee H's Avatar
Why?
Old 09-05-2013, 11:23 PM   #7
rdrnation
Old 09-06-2013, 12:17 AM   #8
In The Ten Ring
Lee H.
I'd like to have the extra stowage behind the seat and sitting on 21 gallons of a highly volatile and flammable liquid.....hmm.....there might be a reason tanks aren't located there anymore. LOL
Old 09-06-2013, 12:55 AM   #9
leddzepp
Moderator
leddzepp's Avatar
It's a mini tool stowage box, lol. I don't know how you could fill a tank through one of those doors, unless the tank hung below the bottom of the fenders. It may be the angle the pic was taken...but the wheel does not look centered in the wheel well, so I would inspect for a cut down LWB frame.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-06-2013, 01:09 AM   #10
rdrnation
thats what i thought too, the vin on the door and the spid match. frame seems uncut. is there a code stamping on the frame somewhere that i can verify it was a shortbed frame?
Old 09-06-2013, 01:12 AM   #11
JOJABOY
original short bed....but replaced wrecked or rusted bed with a replacement long bed that has been diced up? i dunno.
JOJABOY is offline   Reply With Quote
Old 09-06-2013, 02:40 PM   #12
AirSpeed
AirSpeed's Avatar
I had saddle tanks on my 70 GMC short, the filled under the wheel wells, it sucked in the winter, I had to chip off 4" of I've to get to the gas cap. The filler was about the same level as those doors, it had to be for saddle tanks.
AirSpeed is offline   Reply With Quote
Old 09-07-2013, 08:10 AM   #13
Daddy Brim
Daddy Brim's Avatar
If there is nothing behind those doors I would make some storage boxes. Does not need to be to big, jumper cables on one side and some tools on the other.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-07-2013, 11:46 AM   #14
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Check the SPID for the wheelbase 115= Short Bed, most folks dont think to check that when they buy a SWB, but I have run across some 127's in the wheelbase and the guys swore up and down it was a short bed.
I had the same door on a 72, but it was higher for saddle tanks.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 09-07-2013, 11:48 AM   #15
rdrnation
Spid says 115 im baffled
Old 09-07-2013, 12:55 PM   #16
rdrnation
Here is the spid
Old 09-07-2013, 06:38 PM   #17
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Are there any center stake holes? That's the easiest way to find a cut down long bed. Your SPID codes to be a true short bed but in 40-45 years the bed could have been changed.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-07-2013, 06:44 PM   #18
rdrnation
There are no center stake holes
Old 09-07-2013, 07:14 PM   #19
BrianG
BrianG's Avatar
They are they so that you can inspect and lube the front bushing on the leaf spring.
or maybe not.
BrianG is offline   Reply With Quote
Old 09-08-2013, 03:09 AM   #20
71meangreenc10
I wouldn't sweat it....Remove and repair them if you decide to repaint the truck.
Smitty
71 C30 Wrecker
Old 09-08-2013, 09:12 AM   #21
67c10rustbuket
67c10rustbuket's Avatar
Maybe at one point in time there were side steps cut in the bed. PO didn't like them and didn't know how to weld so when he saw a truck with these fuel doors and thought it was a great idea to cover the step hole. That's my guess.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
