Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-06-2003, 02:44 AM   #1
stepside454
stepside454's Avatar
305 & small block perf. parts
Ive got a 305 for sale with very low miles. has Eagle I-beam rods, KB 10:1 pistons (with 58cc heads) comp cams XE256 hyd cam, it is a i piece rear manin block. should be pulled apart & cleaned up before use. also have a pair of L-98 aluminum H.O. vette heads that were on the 305 with self aligning roller tip rockers & flamed centerbolt valve covers.thought there was a knock in the engine... turns out it was a serious header leak. heads have D shaped exhaust ports & the Dynomax headers I had were oval turns out the engine is fine,,, it ran very strong in my 86 Elcamino with 3.08 gear. John
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 12-07-2003, 01:29 AM   #2
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
PRICE
HOW MUCH?
BIGCHEVYMAN is offline   Reply With Quote
Old 12-07-2003, 01:32 AM   #3
stepside454
$500.00 firm for everything since your coming from tennessee...not that its all that far, but Ill be fair
Old 12-08-2003, 12:15 AM   #4
BIGCHEVYMAN
is the motor torn down? just curious what it would need to run. thanks
Old 12-08-2003, 12:48 AM   #5
stepside454
heads are off, if it were me Id take it apart & clean. should be all it needs. the engine ran great & strong. sold the car without the engine. pulled the heads off last spring, because a guy wanted to look it over & wanted to see the KB pistons. He never called back. so there it is. I built it about a year & a half ago.
Old 12-08-2003, 01:14 AM   #6
stepside454
here a pic of short block
Old 12-08-2003, 01:17 AM   #7
stepside454
& heres the heads.. you can see rust on back side of valves. last spring I had the engine out of the car & had the short block @ my machine shop. we had a flash flood in May, flooded the car & the house & garage
thats how the valves got rust. the short block wasnt effected, it wasnt here.
Old 12-08-2003, 07:30 PM   #8
BIGCHEVYMAN
What
what year is the block? if you still have it after christmas i am definately interested. are you interested in any trades? if so let me know what you need. i have several 4x4 parts. thanks john c.
Old 12-08-2003, 07:39 PM   #9
stepside454
its an 86 block with the 1 piece rear main non roller. I dont need any 4X4 stuff, need some odds & ends for my 75C-10 2wd though.
I need the plastc vent that goes over cowl, infront of the wipers, its a screen, should be able to find it for a few bucks at salvage yard.
3.73 gears for my 1/2 ton 12 bolt truck rear
maybe a BB single plane intake
a pair of nice headlight bezels
like I said odds & ends.
the motor really was strong. with the 3.08 posi in my 86 Elky it would barely chirp the tires from a dead stop, but by 2500 RPMS & a few feet out it would bust the 255/60s lose. & on the hiway, man for a lil 305 it sang. had a performer intake & a 570cfm holley on it.. I learend a lesson the hard way. dont use Dynomax headers with these heads. the heads are D port exhaust ports. I spent countless hours & $ trying to find an engine noise that turned out to be a header leak.
Old 12-08-2003, 08:03 PM   #10
BIGCHEVYMAN
stuff
i have the screen that goes on the cowl panel. that only big block part i have left is a crankshaft pulley. i will check the headlight bezels i have a bunch of those. i also have a complete 3:73 rear that came ont of a 78. john c.
Old 12-08-2003, 08:18 PM   #11
stepside454
Im not sure what years that screen interchanges with 75, be cool if it is correct ( & any hardware that goes with it) my LMC book shows 75-76 is the same headlight bezelz...dont know how much differant 77-78 are, could be minor, not sure. not sure if I want a complete rear end or not. Thanks John
Old 12-08-2003, 08:24 PM   #12
BIGCHEVYMAN
the rear end is the only thing
the rearend is the only thing that is out of a 78. i have a 73,75,2-78's,80,81 and 84 parts trucks. i will part the rear and pull the gears for you if you want to consider doing some trading. thanks john c.
Old 12-08-2003, 08:37 PM   #13
stepside454
now that might be an idea. Id consider some trading, makes everyone happy. also could use a nice battery box & bracket.
Old 12-09-2003, 08:44 PM   #14
BIGCHEVYMAN
addy
e-mail me so i can keep up with you. after christmas i am going to buy a engine. this is what i'm looking for(something different). thanks john c.
Old 12-09-2003, 08:48 PM   #15
stepside454
mine is stepside454@sbcglobal.net
