Old 09-07-2013, 06:56 PM   #1
87chevyk10
35s with 2 inch lift?
Hi, I have a 1987 v10 with a 2 inch lift. 7 leafs in back 4 in the front. Will 35s fit??
87chevyk10 is offline   Reply With Quote
Old 09-07-2013, 07:57 PM   #2
Rubble
Re: 35s with 2 inch lift?
It might be pretty snug fit,depends how wide your rims are & how wide of 35s.They might fit on 8" rims if the rims tuck in under the wheel wells.I have a 86 on 35s with 7" lift and a 82 with 6" lift,both on 10" wide rims & both have fenders trimmed too.Depends how rough you want to use the truck too!!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 09-07-2013, 08:26 PM   #3
87chevyk10
I have the stock rallie rims on it.
Old 09-08-2013, 12:56 AM   #4
Rubble
You might be good with the rally's,worse case you might have to trim the fenders a bit.
Old 09-08-2013, 01:03 AM   #5
eray92
eray92's Avatar
I had an 86 Silverado with a 6 inch lift on 35x14.50 15s on 12" wide wheels. never had an issue with rubbing.
if you have stock 15x8 rallies you could run a 35x10.50 with little to no rubbing iirc
Also depends on manufacturer of tire
eray92 is offline   Reply With Quote
Old 09-08-2013, 01:07 AM   #6
eray92
eray92's Avatar
here are 31" or 32" on stock height and I had plenty of room also. wheels stuck further in the wells
350, chevy, silverado
