Old 09-08-2013, 10:16 AM   #1
Skunksmash
Skunksmash's Avatar
What I'm goin do?
Well for some reason, the guy who painted my truck broke the door striker plastic. Don't know how, other than he was dumb. So the other day I went to replace it, and you can see the results in the pics. The nut that it goes into has fallen down inside the cab. I took the speaker out looking for it, but I couldn't find it. I guess maybe it got down there too far. I may try again to find it, but what if I can't?
How should I go about completing this repair, if I can't find that original nut? It somehow fits into that square hole perfectly. So another random nut from the hardware store won't cut it.
Skunksmash is offline   Reply With Quote
Old 09-08-2013, 10:20 AM   #2
J Knight
J Knight's Avatar
Re: What I'm goin do?
Junkyard part.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 09-08-2013, 10:39 AM   #3
BONUSCAB
Step 1: Magnet on a long flexible stick (coat hanger comes to mind.)
Step 2: Go fishing!
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 09-08-2013, 11:19 AM   #4
tucsonjwt
Harbor Freight sells a long flexible magnetic retrieval tool with a light on the end. It only costs a few dollars. I keep one handy in my tool box and use it all the time. It has quite a strong magnet. The light went out long ago, but the replacement battery costs more than a new tool.
tucsonjwt is offline   Reply With Quote
Old 09-08-2013, 11:23 AM   #5
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
It's in there. Keep looking and you will find it.
If you don't find it, like someone else said, head to the wrecking yard.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 09-08-2013, 11:29 AM   #6
BONUSCAB
The only reason any self respecting American has for walking into Harbor freight is to spill gas and toss around lit matches. Buy American.
Old 09-08-2013, 11:32 AM   #7
jjzepplin
jjzepplin's Avatar
I have this "rare earth" neodymium type magnet that I use from the outside. I glued a piece of felt to it so it won't scratch the paint and then just run it around the area where you think the bolt is and roll it back up to the hole. Have done this several times on motorcycles and cars. Work good to find ball bearings etc in the dirt too. Hate when I drop stuff!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-08-2013, 01:20 PM   #8
LynnJr
Leave it in there and use a nutsert to finish the job.If it rattles add silicon.
LynnJr is offline   Reply With Quote
Old 09-08-2013, 02:12 PM   #9
INSIDIOUS '86
INSIDIOUS '86's Avatar
When the plastic breaks a good quick fix is electrical tape on the striker wrapped around a bunch. Works like a charm
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-08-2013, 02:18 PM   #10
Corts60
Just here to tinker
Corts60's Avatar
Perfect.
Old 09-08-2013, 02:55 PM   #11
S10Fan
Old Heap Driver
I'm sure the Americans working there would appreciate that. Did you type that statement on an American computer?
This is a truck forum, political comments are best left to other forums.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 09-08-2013, 03:51 PM   #12
Skunksmash
Skunksmash's Avatar
Is there a way to do a nutsert without some kind of special tool? Found this, but I'd like to avoid spending a lot of money on this fix.
Old 09-08-2013, 05:19 PM   #13
79Betty
79Betty's Avatar
Long bolt with the plastic on it and a nut couple washers?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-08-2013, 05:33 PM   #14
S10Fan
Old Heap Driver
http://www.fjr1300.info/howto/rivnut-tool.html
I've installed them without the tool, but the tool is handy. I've installed a bunch of them over the years for all sorts of brackets, makes for a very clean install.
Bryan
Old 09-08-2013, 05:58 PM   #15
jitteryguy
GoatLube Experss
jitteryguy's Avatar
you can buy sqare nut's at Lowe's or most any hardware store.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 09-08-2013, 06:10 PM   #16
eray92
eray92's Avatar
what about LMC for this problem?
eray92 is offline   Reply With Quote
Old 09-08-2013, 06:16 PM   #17
LynnJr
On the NutSert you don't need a $160 tool to do just one or even 10.
I use a bolt that isn't threaded all the way a second nut and 5-6 washers for the spacer.I will be doing some this week for grille brackets and will try and post you some pictures.
You can get a couple from McMaster-Carr for a lot less money than many other places.I bought mine on e-bay and 5 Nutserts were $10 with shipping so look elsewhere.
http://www.wranglerforum.com/f19/cre...ze-202021.html
If you scroll down on the above link you will see a Nutsert on a homemade tool that works just fine.
Old 09-08-2013, 07:45 PM   #18
Skunksmash
Skunksmash's Avatar
Ok I guess I'm not really visualizing what you guys are saying. The nutserts are round, that hole is square...
Old 09-08-2013, 08:00 PM   #19
ElGracho
ElGracho's Avatar
For this application, hardware store nuts or nutserts are not the right thing to use. Fish the big square nut out of the b pillar behind that speaker. It's like 1 1/2" square, it can't be that hard to find.
Joe
Old 09-08-2013, 08:03 PM   #20
LynnJr
You can get square Nutserts but remember the Nutsert is bigger than the bolt and it has its own threads.
This means you need to order a Nutsert with the correct threads then drill the hole to the correct size.
I am using 5/16 coarse Nutserts and drilling the holes to 0.500 then inserting the Nutsert and crimping it into place so it won't spin.
In your case you can get a square Nutsert use a round Nutsert and ignore the small void area or you could use a J-Bolt or U-Bolt but the last two may require you to enlarge the hole.
They sell all kinds of stuff that will work even molly bolts made just for steel.The advantage to the Nutsert is it doesn't stick out a lot in the front and move your striker to much.
Old 09-08-2013, 09:22 PM   #21
J Knight
J Knight's Avatar
If your going to use the nutzert idea it needs to go on a big washer or piece of metal behind the square hole. The striker need to be adjustable. But I would just run to the junkyard and get the right part.
John
Old 09-08-2013, 09:28 PM   #22
GM_For_Life
GM_For_Life's Avatar
Yeah I did this for a while on my old suburban, the new strikers cost $20 bucks at napa and the ones I pulled from the scrapyard don't quite cut it. It's only stupid if it doesn't work!
"Yeah, that'll probably work..."
-1967 Olds Delta 88 (sold)
-1977 GMC High Sierra
-1988 Chevy Suburban v10 (sold)
GM_For_Life is offline   Reply With Quote
Old 09-09-2013, 06:13 AM   #23
S10Fan
Old Heap Driver
"Like"
Bryan
Old 09-09-2013, 07:28 AM   #24
Skunksmash
Skunksmash's Avatar
I used a piece of PVC on the other side. But I wanted a new part this time that looked like it was supposed to go there. Also I got mine from Orielly's for $8. Napa is a ripoff, but we all probably already knew that.
Old 09-09-2013, 08:08 AM   #25
Rich84
Rich84's Avatar
Pex tubing works great..Don't look bad either.
Rich84 is offline   Reply With Quote
