Old 09-10-2013, 07:48 AM   #26
MARKDTN
Re: veiws on using the 283?
I have this pipe dream of a Stepside shortbed with blueprinted/balanced 283 fuel injected & overdrive for the ideal interstate road trip classic. Not looking for speed,looking for go go go go go...with great effeciency
That's what I was going to say. 283 with Tuned Port fuel injection would be really cool. TPI was designed around a 305 so they have plenty of flow for a 283. Lots of low end torque. Couple that with a 700R4 with a deep first gear and you have a great combo.
Bear in mind todays V8 truck engines are 4.8, 5.3, and 6.0 Liters so in cubic inches that's 292, 323, and 366. You can get a good bit of power from a small package with fuel injection. You don't have to have a dual carb 454 to make good power.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-10-2013, 08:32 AM   #27
jus2qwk
jus2qwk's Avatar
by far the best budget engine build that made quite a bit of power that I've ever done was the 408 I had in my truck when I first built it. such an easy combo and can be done super cheap. basically what I did is found a sbc 400 cleaned up the cylinders, stock crank, stock 350 rods (5.7), ordered a cheap set of pistons, and had set of stockish 300hp heads (041 casting), decent sized cam, and aluminum intake. all in all I had a little over 1000 bucks in the whole motor and I'm fairly sure i was getting 1hp per cubic inch. super cheap, a ton of fun to drive, and very streetable
like it was said before there is no substitute for cubic inches!
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 09-10-2013, 08:32 PM   #28
Efficiency is a great substitute for displacement
Old 09-13-2013, 10:37 AM   #29
bigmac73
bigmac73's Avatar
i think you would spend more in the long run trying get more from less, plus stress out the block and rotating assembly, more Cubes means more power and a more stable base to build on.
a 350 cid at 300 HP is pretty cheap and common build
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
