Old 12-06-2003, 07:29 PM   #1
1985K10
1985K10's Avatar
TH400 Not shifting
The 400 in my dads plow truck (84K30 6.2L Diesel NP208) shifts into second hard, and wont shift into third. Its not slipping at all. I was thinking it the Vac. modulator, but where under the hood does it hook up? Is there a pump or something that makes vacuum?
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 12-07-2003, 10:35 AM   #2
77bowtie
Look behind the carb at the intake manifold, you should be able to follow the vacuum line up from the tranny. Runs infront of the distrubitor. Good Luck...Jon
77bowtie is offline   Reply With Quote
Old 12-07-2003, 06:03 PM   #3
Cole's 87
Cole's 87's Avatar
what I would do is start at the modulator and follow the line to where it connects to the engine
If the line hasnt come off the modulator pull it off and see if there is any trans fluid in the line or comming from the modulator. If so replace it. If not start looking at the other componets.
Cole's 87 is offline   Reply With Quote
Old 12-08-2003, 01:55 AM   #4
1FaastC10
1FaastC10's Avatar
TH400 doesnt have a vac modulator, if i remember correctly.
1FaastC10 is offline   Reply With Quote
Old 12-08-2003, 03:54 AM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
TH350s and TH400s have modulator valves, though you might be thinking about the different kickdown setups. TH350 is cable and TH400 is an electric solenoid.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-08-2003, 04:36 AM   #6
Frank-id
TH 400 no shift
It is hard to kill a Turbo 400 trans. Most shift problems are caused by defective govenor. This is a device on right side of trans under round cover with 4 bolts.
Pull th govenor straight out. Look device over and check for any bent, broken or changed parts. Most repair manuals will give an overview and some check points.
The most important consideration is the weights and valve MUST move freely.
A used unit is as good as a new unit. If unit has any metal missing, a filter and fluid change are needed....
The govenor is on the side of the trans case NOT in oil pan.......
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
Old 12-08-2003, 01:19 PM   #7
Jonboy
Slots go on anything!
It seems like the vacuum pump is towards the front of the engine on a 6.2 . It has been a long time since I have looked at one, but that seems right.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
