09-18-2013, 01:43 PM | #1 |
What tank do I have?
Below are some pics of the tank that is rear mounted in my 69 K20. I should note the frame is a 78. At least I think it is.... Anyway the tank does not look like anything in the LMC catalogs and I want to order a new fuel pickup and straps. The tank itself is in good shape. The existing pickup has vent lines and such for a charcoal canister that I am not using. You can also see how deteriorated the rubber fuel line was. Yikes. It has been years since I filled it up and only dropped it so I could empty the few gallons that were still in there. The filler goes to the passenger side of the bed. Thanks all for your help!
1969 Chevy K20 Longbed |
09-19-2013, 10:13 AM | #2 |
Re: What tank do I have?
Anybody??
09-19-2013, 11:46 AM | #3 |
Member #1049
it looks to be a mid-late 70's Blazer or Burb tank
09-19-2013, 01:42 PM | #4 |
The last time i pulled a tank that looks just like your pic with that many vents and a return it came from a 1989 diesel suburban.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
09-19-2013, 02:11 PM | #5 |
Is it approx. a 40 gallon tank? is so, I may be able to help.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
09-19-2013, 02:47 PM | #6 |
Here is one out of an 87 burb I parted, 40 gallon
Sending unit a little different bc it was tbi Posted via Mobile Device
1969 C10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=580422 1981 C10 SWB 1995 ECSB Bagged |
09-20-2013, 06:36 PM | #7 |
So I guess it is looking like a 40 gallon diesel tank? At least now I know and LMC does have pictures and even dimensions in there catalog. I guess it helps to flip to the 73-87 section if my frame is a 78....
40 gallons...I am never going to fill that up.
