Old 09-19-2013, 11:35 AM   #1
bguild
bguild's Avatar
Brake Pedal Ratio for a 1967 with factory brake pedal?
Okay i need to know the Brake Pedal Ratio for a 1967 chevy truck. Mine is torn apart and I need to know the Brake Pedal Ratio in order to figure out what Master Cylinder to run with my Z06 brake calipers.
Thanks in advance.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 09-19-2013, 11:53 AM   #2
geezer#99
geezer#99's Avatar
Re: Brake Pedal Ratio for a 1967 with factory brake pedal?
Should be 6 to 1. Measure it! Full length divided by distance from top to pushrod hole.
Old 09-19-2013, 12:28 PM   #3
bguild
bguild's Avatar
My brake pedal is not in the cab or I would (-;
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 09-19-2013, 12:34 PM   #4
Keith Seymore
Keith Seymore's Avatar
This is true.
This is too bad! (lol).
It probably depends too on if your truck was originally power or manual brakes.
I don't have anything for '67, but I do have the brake system release charts for '74 and for '87. Scan through there to get a feel for the numbers.
http://67-72chevytrucks.com/vboard/s...d.php?t=510519
Looks like most of them are around either 4.5:1 or 6:1.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-19-2013, 12:37 PM   #5
bguild
bguild's Avatar
Thanks for the help!!
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 09-19-2013, 12:46 PM   #6
geezer#99
geezer#99's Avatar
Even easier with it out. Same way to measure it.
While you're at it drill another hole 1 1/2 inches below the other pushrod hole. It's needed for power brakes because the ratio needs to change to 4.5 to 1.
Old 09-19-2013, 01:00 PM   #7
bguild
bguild's Avatar
Okay I will look at it later then. I am running manual brakes. I think with Z06 6 piston calipers and correct master I shouldn't need a booster.
Toys:
2014 Dodge Ram
1967 SHORTBED
