![]() Join Date: May 2010
Lowering blocks for an AD
I am trying to find lowering blocks for the rear of my 54 will no luck. Has anyone been able to find a 1 3/4" wide block?
Re: Lowering blocks for an AD
it wouldn't take much modification to use 2" blocks. Those are easy to find
yeah me to a lot easier and cheaper local suspension shop hooked up the u bolts. the guys at the metal shop gave me a few scrap pieces of square tubing they couldn't sell.
You can get by with heavy wall tubing but grinding notches in the 2 inch wide lowering blocks to clear the U bolts.
If you use square tubing use the thickest wall tubing you can get as thin wall tubing has a good chance of crushing. Here is a link to some 3 inch lowering bocks that will bolt on complete with U bolts but they are not inexpensive in my opinion. Three inches may be too much too. http://shop.kustomcarparts.com/Chevy...-Kits_c195.htm 80 bucks for blocks and U bolts is a bit on the expensive side for me.
Thank you for the all of the input. I was thinking of using 3" channel and boxing it in with 1/4 flat strap. I will have to see if I can come up with some 1 1/2 x2 tubing next week.
Posted via Mobile Device |
#7 | |
![]() ![]() Join Date: Nov 2008
Most metal supply places have a scrap bin for cut off pieces of material where you could likely find what you need to make your own, don't you think?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
