Old 09-20-2013, 05:37 PM   #1
swissarmychainsaw
Gusher at Fillup!
OK, this HAS to be a common problem.
Go to fill up and gas goes everywhere.
It's bad enough that modern nozzles won't stay in the filler neck, but now I'm gushing gas all on the ground!
PO said that he "fixed" the rubber boots. Maybe not tight enough?
Seems that there is one in there that is cracked.
Thoughts on this?
Thanks!
--Nick
swissarmychainsaw is offline   Reply With Quote
Old 09-20-2013, 07:31 PM   #2
donut
donut's Avatar
Re: Gusher at Fillup!
If it seems one is split, and maybe not tight enough, may be time to pull it apart. Fairly safe to say the copper 90 is not factory.
PO fixed it long enough for it not to be his problem anymore.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 09-20-2013, 08:20 PM   #3
swissarmychainsaw
HAHA yeah.
I never thought that the 90 bend would not be stock.
Who has a pic of what it should look like?
--Nick
Old 09-20-2013, 08:50 PM   #4
Brockwaykid
Brockwaykid's Avatar
I would be able to get one off a 75 but the pass side is deep in a brush pile. lol
Jeff Shaw
2003 Chevy 2500HD LB7 Duramax
Brockwaykid is offline   Reply With Quote
Old 09-20-2013, 10:58 PM   #5
jd21476
jd21476's Avatar
I just ordered and installed new hoses from LMC but it does not fix the issue. It has to do with the CA gas pump and all that plastic emissions stuff that prevents it from getting in the filler tube deep enough.
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 09-20-2013, 11:12 PM   #6
Oldriginal86
Had the same issue with an 86 K20 a few years ago after installing aftermarket plastic tanks. Could be the copper 90 fitting is restricting the flow. Check the vent also, air has to come out somewhere while the fuel is going in.
Oldriginal86 is offline   Reply With Quote
Old 09-21-2013, 12:01 AM   #7
mongoose
mongoose's Avatar
whats leaking? find the leak and replace if its cracked etc.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-21-2013, 07:01 AM   #8
andrewmp6
If the hoses he used are not gas rated they will leak over time.
Old 09-21-2013, 10:15 AM   #9
75chev4x4
75chev4x4's Avatar
Yea double check your vent.
75chev4x4 is offline   Reply With Quote
Old 09-21-2013, 10:18 AM   #10
jd21476
jd21476's Avatar
Here is a link that I started a few weeks back where we discussed this same issue in detail.
http://67-72chevytrucks.com/vboard/s...d.php?t=593288
1973 Chevy K20
Old 09-21-2013, 11:57 AM   #11
Corts60
Just here to tinker
Corts60's Avatar
Here is what the factory 90 looks like:
I am going through this dilemma with my truck right now. They are not leaking but I want to replace them. The only place I can find them is Classic Industries and they want like $38 a piece for them. That's crazy prices.
Old 09-21-2013, 12:15 PM   #12
jd21476
jd21476's Avatar
LMC sells them $19.95 each
1973 Chevy K20
Old 09-21-2013, 02:55 PM   #13
MusicMan70
MusicMan70's Avatar
Here's a another angle on my 73 Pass side.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 09-22-2013, 01:52 AM   #14
swissarmychainsaw
On mine the smaller tube which is the return or vent I think is all cracked and worn.
AND the clamps were loose. Tightening them helped but I need to order new stuff and replace.
Its bad enough that the CA nozzles don't fit the filler necks. They don't let the nozzle sit on its own you have to hold it in place!
Old 09-22-2013, 11:44 AM   #15
lowesguy
lowesguy's Avatar
I've lived with that issue for 20 years!,something wrong with the design? I've replaced the lines from dealer parts oem,still have issue,it has to be vent problem,or at the time my 78 was made gas pumps were slower now they pump really fast,have to have the pump at a certain angle,and slow the pump down,irritating, also I think the pump seal covers the vent hole and can cause the problem. back in 78 the pumps didn't have that big rubber seal on them, live with it man,or go crazy!
Thanks John!
lowesguy is offline   Reply With Quote
Old 09-22-2013, 02:46 PM   #16
gramps77
Is there a filler neck that has the smaller inlet in it with the little flapper door that we can swap out? Wouldnt that stop the splash back? I seem to find a nozzle here or there at different gas stations that dont splash like the other but they are few and far between
gramps77 is offline   Reply With Quote
Old 12-31-2013, 11:52 AM   #17
swissarmychainsaw
Thanks!
--Nick
I ordered the correct replacements from LMC Truck. They were $19.95 each which I am happy to pay at this point. Spewing gas at every fillup is not so great!
Old 12-31-2013, 12:07 PM   #18
bnoon
If I put the pump on full blast and lock it in, there's a big splash at the finale. I tend to pump about 15 gallons, then knock it down to the first step. When it finishes I don't get any splash most of the time, but every so often it still spits out a little bit. It's gotten to the point that I'm ready and waiting with the window washer squeegee every time I fill just in case.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 12-31-2013, 03:17 PM   #19
oneday1
I replaced these on my truck because they were looking worn and cracked. Found a source on ebay for fuel line for marine use and the hoses were about $3. Had to cut to fit of course but the price was right and had enough for both tanks.
Although the OP's photos look like there is in fact a leak somewhere the compression nozzles at the newer fuel pumps always throw gas if not held far enough in and slightly angled. At least be thankful you're in CA and can do it yourself. Here in Oregon they've found that driving thousands of pounds of metal at 65 mph is fine but putting fuel into it is just too dangerous for the common man so only highly trained specialists can pump our gas.
oneday1 is offline   Reply With Quote
Old 12-31-2013, 05:35 PM   #20
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There's your law makers. Rather than risk some gas vapor escaping during fill-up, they mandate complicated nozzles that cause people to wind up burping gas onto the ground instead. I'm sure we will get them in Texas eventually.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-31-2013, 05:57 PM   #21
wilkin250r
wilkin250r's Avatar
Hmm. Probably a market in California (maybe other states) for a complete new filler neck that is designed to work with today's pumps. I'll look into it.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 12-31-2013, 07:53 PM   #22
Jonboy
Slots go on anything!
Unfortunately, they have made it to the metro areas. Filling up my truck in Dallas county was a beating. Drive it to work and fill it in Ellis county, easy peasy. You almost had to lay on the ground and contort yourself to get the vapor nozzles to work.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
