Old 09-21-2013, 03:49 PM   #1
scott-wisc
scott-wisc's Avatar
Why isn't this working?
Summit Racing alt bracket SUM-g4017. Do I need a different alternator, I thought they we're all the same as far as mounting went.
scott-wisc is offline   Reply With Quote
Old 09-21-2013, 04:22 PM   #2
vidman
vidman's Avatar
Re: Why isn't this working?
have you tried flipping the bottom bracket around...???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 09-21-2013, 04:56 PM   #3
68gmsee
Active Member
68gmsee's Avatar
That alternator top mounting looks somewhat different. I'll look at mine and take a pic to compare.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-21-2013, 05:12 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I think it was optical illusion. Looks pretty similar to mine which is stock 75 chevy 350.
Is your problem that the pulleys don't line up if you were to tweak it to fit?
06 Trailblazer
Old 09-21-2013, 05:23 PM   #5
ItsRandy
ItsRandy's Avatar
Is that the stock alternator or high output? There are a bunch of different alternator frames out there. It looks like your alternator frame doesn't match your brackets. The alternator on the ground looks like the correct frame.
ItsRandy is offline   Reply With Quote
Old 09-21-2013, 06:14 PM   #6
geezer#99
geezer#99's Avatar
Your bracket's not made for your air gap intake. And you need a spacer to move it forward.
Old 09-22-2013, 12:40 AM   #7
steve9484844
I'm with vidman.
steve9484844 is offline   Reply With Quote
Old 09-22-2013, 12:57 AM   #8
wreckedchevy
wreckedchevy's Avatar
I'm with you on this one I have the same looking mounts on mine and it doesn't have the airgap intake
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 09-22-2013, 01:53 AM   #9
airdale94
airdale94's Avatar
What you need to do is leave the mounting bolts loose on the the bracket then feed the alt. in and put the adj. screw in. I ran into this with my Perf. RPM.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 09-22-2013, 06:49 AM   #10
scott-wisc
scott-wisc's Avatar
So that's what the spacer is for! It came with the intake, but I didn't know what it was for. I did get it to work by loosening everything, putting the alt in place and then cranking all the bolts down. Some of the chrome flaked off and the alt doesn't slide smoothly. I'll play around with the spacer and see what I come with.
