Old 09-22-2013, 05:53 PM   #1
rodncustom
1972 Blazer Seat/Seatbelts
New here and to full size Blazer ownership.
I have a 1972 Blazer missing a couple of parts that I'm having a difficult time locating. I have a complete set of original seat belts in great condition so no need to replace them but no mounting hardware. It appears that there are existing threaded bolt holes to mount to but I do not have the correct bolts. Is there a supplier for these? I am looking for this both front and rear. I also can't see where the front seat belt mount. Perhaps under the carpet and holes weren't cut out during restoration?
Also, for the rear seat, it appears from my research that the rear seat should have four total legs going from left to right across the back...and I am missing the two inner legs. I also am missing the bracket that holds down the front of the seat frame to the floor.
Lastly, I have the Bright Blue interior and am missing the arm rests for the back seat. I have found several suppliers of Black ones but no one seems to carry them in the various colors. Do I just buy the Black ones and have them painted?
Thank you.
Mark Murray
rodncustom@hotmail.com
rodncustom is offline   Reply With Quote
Old 09-22-2013, 10:44 PM   #2
jaros44sr
jaros44sr's Avatar
Re: 1972 Blazer Seat/Seatbelts
1did you look on the step up that leads to the rear bed floor, thats where the factory mounted the forward seat belts
2 let me look and see if i still have the legs off of my rear seat
3 there is a good supplier of quality interior parts on the board, ill have to get back to you on his name
4 i would recommend that you start hanging out in the parts classified section, lots of good people and parts down there
Thank you.
Mark Murray
Welcome aboard, we require pics of your truck for our own enjoyment (j/k), but does help us to identify any problems you may have in the future
Also, if you turn blue, you can post up a WTB in the classified section, which will get you a more speedy response, rather then the message board.....sorta frowned on, but youre new, so you will learn the ins and outs around here
Sit back and read, lots of good info going on
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-23-2013, 07:48 PM   #3
Chulisohombre
Chulisohombre's Avatar
You should be able to get those parts at lmc truck.com or brotherstrucks.com .try those first. They have detailed breakdown of parts and bolts and where fasteners bolt onto the body. There are I believe 13/16 bolts i believe they are. to the inside and outside of the seat frames for the seat belts.
Chulisohombre is offline   Reply With Quote
