Old 09-22-2013, 08:33 PM   #1
70CHEVYBB
70CHEVYBB's Avatar
blanked up turn signal, PLEASE HELP ME
I turn on my left turn signal and here's what happens----- dash lights flash, tail lights, grill lights, and all side marker lights flash. I have driven the truck for a week with no problems, I installed a ground from the rear cross brace to the frame and that's when I noticed it started screwing up. I removed the ground and didn't help. I have all new bulbs and have the following grounds, battery to radiator support, battery to block, block to frame, side marker lights to radiator support in front, side marker lights to bed in rear. Both head lights to radiator support. All grounds were attached to bare metal. The right turn signal works perfect. any help would be great cause I can't drive it til I get it fixed.
70CHEVYBB is offline   Reply With Quote
Old 09-22-2013, 11:27 PM   #2
CastIron
CastIron's Avatar
Re: blanked up turn signal, PLEASE HELP ME
You have a short circuit between the left turn signal circuit and the parking lights. If the same thing happens when you hit the brakes, it's probably in the taillamp. If the brake lights work normally, it's probably in the front turn signal. Check your bulbs. One may be in backwards, or have a short internally.
CastIron is offline   Reply With Quote
Old 09-23-2013, 08:51 AM   #3
70CHEVYBB
70CHEVYBB's Avatar
all new bulbs and not in backwards. brake lights function normal. Not sure if the turn signal switch can cause this or not.
Old 09-23-2013, 04:38 PM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
I'd guess it's the switch. I've experienced similar symptoms, and gone through 3 replacements in the 16 years I've had my truck.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
