Old 09-23-2013, 08:40 PM   #1
briank
hatch hardware part help
I have began work on my 72 K5 and noticed on the rear bed sides where the metal hardtop bracket attaches to the body, the threaded insert has pulled out and are gone. Anybody know if I can buy something that would work from the hardware store. I have attached a picture of another 72 I had that shows the location of the part I am talking about but it is actually inside the bedside.
briank is offline   Reply With Quote
Old 09-23-2013, 09:24 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: hatch hardware part help
Good question, I removed my hard top for the summer and the nut sleeve just spun in the hole on drivers side. Had to use persuasive tactics! I was going to check LMC catalog, if no luck there then Ace hardware the Fastnal.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-23-2013, 09:32 PM   #3
patdaly
Brian, not the cheapest fix, but probably the most secure.
http://www.mcmaster.com/#standard-th...nserts/=on0x46
Tool to install is expensive, someone just loaned one out in one of the blazer build threads, wish I had one myself, I would loan it to ya.
patdaly is offline   Reply With Quote
Old 09-23-2013, 11:22 PM   #4
jaros44sr
jaros44sr's Avatar
There is a cheap tool to squish the nut sert, but you could cut an access hole in the upright to hold the spinning nut
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-24-2013, 11:44 AM   #5
steve9484844
Should be an access hole in the rear that you can stick a wrench through, just lube up your wrench and put a piece of tape on one side of the box end and use it to hold the nut in place as you thread the bolt.
steve9484844 is offline   Reply With Quote
Old 09-24-2013, 09:07 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
There is no nut on the inside, just a round sleeve with threads. The sleeve is tightly compressed against the body sheet metal. When the sleeve spins there is not enough access to get any kind of tool to grasp it. Cold chisel and hammer - then replace the nut sleeve.
Old 09-25-2013, 09:34 AM   #7
briank
Here's the fix I found at the hardware store for $1.20 ea. Ill enlarge the three holes, tack weld them and flush grind them.
Old 09-25-2013, 10:19 AM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
There ya go! Bam!
I'll use the same process...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 09-25-2013, 11:01 AM   #9
mtully79
mtully79's Avatar
Great fix! I'll be doing the same when the top goes on in the winter.
mtully79 is offline   Reply With Quote
