1972 402/th400
Hey all. Looking to sell my original 402 BB with attached th400. Edelbrock intake manifold, edelbrock electric choke carb (600 or 750, I'll have to check), high torque mini starter, high amp chrome alternator, HEI distributor, MSD wires, Alan groves brackets for AC and alternator, power steering pump and reservoir, clutch fan, engine stands. The rest is pretty stock. Ran really good, shifted great. Smoked a little if you really romp on the gas. Used a little oil (don't most big blocks!) only pulled for ls swap for better gas mileage.
I also have the original intake and quadrajet, as well as frame stands. Any idea what it's worth? Thanks! Shawn Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 09-26-2013 at 07:41 PM. |
Re: 1972 402/th400
Anybody?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Mar 2011
Re: 1972 402/th400
i have one to sell runs real ruff sat for long time popping thru carb has 400 attached to it still in the burb all the smog crap on it did you sell yours or do you have any advice
thanks jz
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: Jan 2007
Re: 1972 402/th400
not an expert on engines really, but it seems like a NON rebuilt, complete, running, original bbc will go for $400 to $800. i've seen a lot paired with a trans going for $500 to 1000. the aftermarket parts probably add some value from there too... you may want to start around $1,200 or so. again, not an expert!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#5 | |
Re: 1972 402/th400
