exhaust tube routing.
Wondering if anyone has some pictures of exhaust routing on a 65 c10 lowerd truck. just bought a kit from Jegs that was a good price to pass up. thanks
![]() Join Date: Mar 2013
Re: exhaust tube routing.
V8 or Inline 6?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
V-8. sorry bout dat.
It's Better With Nitro
Are you looking for photos of exhaust tubing routed to the inside of the frame rails, or to the outside?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
I'd Ike to see both.
Posted via Mobile Device |
![]() Join Date: Mar 2005
See post 159 of my '64 build thread. There's some shots of what my exhaust looks like. 2.25" pipe, routed between the frame rails, between the trailing arms, and tailpipes dumping behind the rear wheels.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
meowMEOWmeowMEOW
I'm running a true-dual setup with a side dump. It runs outside the frame 95% of the way, and tucks under the rockers. You can see it going together around the 3rd or 4th page on my build.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Looking to see inside frame rails and outside just to get a ruff idea.
3-inch tubing routed to the outside of the frame rails...
![]() ![]() ...muffler located behind the cab, under the bed with turn out in front of the rear tire... ![]()
Here's a piss poor shot but it's 3inch and comes out right before the tire. It is hanging below the frame tho.
Live and let live ![]() |
Prolly pretty close to the kit tho welded like you can do at home.
The guy above me had a kick as set up but short headers so this gives ya two options anyway.
good set-up vin63. on familyfast64 i'm trying to stay above frame rails because i'm gonna lower the truck 5 1/2 front and 6 rear i would have no room there.
I understand, just thought you might have full length headers. I agree tho, tucked up right is nice, but I will say mine is lowered and I have room but it's not slammed. Your progress looks awesome tho keep it up.
#15 |
Oh I guess I'm complementing vin63. I'm sure yours looks awesome to tho.
#16 | |
