Old 09-27-2013, 11:53 PM   #1
B_derK20
Putting a pickup bed on a c&c
I picking up a new square next week but I don't think I did enough research into what I was buying. It's an '87 V30 with no box or bed. I got it thinking it would be easy to just throw a regular long bed on it. The truck has a 2 piece drive shaft and a 14 bolt so I'm afraid it's a 60 inch c&c model and not 56 inch regular pickup.
How much of a hassle would it be to put a bed on this truck ?
B_derK20 is offline   Reply With Quote
Old 09-28-2013, 02:37 AM   #2
andrewmp6
Re: Putting a pickup bed on a c&c
The bad news the rear end is more narrow then a normal pickups and the frame is longer then a normal long bed.The good news you could shorten the frame to long bed or even short bed if you want.The rear end you can keep if you put a lift on it or replace it for a pickup one.
Old 09-28-2013, 09:34 AM   #3
Phillip Pennartz
"The bad news the rear end is more narrow then a normal pickups"
Does this mean the tires will rub the bed?
I have a 1977 c30 c&c single cab.
Phillip Pennartz is offline   Reply With Quote
Old 09-28-2013, 09:46 AM   #4
1slo_camaro
Could you just run spaces on the rear to push the wheels out? or get a different offset for the wheels ??
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 09-28-2013, 12:09 PM   #5
rs74
rs74's Avatar
I have had the thought about cutting my C&C K30 down to be able to put a dually bed on it but think I will just try to buy one that has the bed on it already. Althought the C&C frames are a bit more beefy I don't I will have it loaded to the point where I can justify the need for the extra thinkness of the frame.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 09-28-2013, 01:07 PM   #6
B_derK20
When I saw the 14 bolt ff I was thinking that it was just a truck that someone put utility box on in place of the pickup box. Later when I remembered it had a 2 piece driveshaft I wondered if it may be a c&c. From looking at it with the box that the guy had on it it didn't look like the wheelbase was longer than a regular pickup but my eyes aren't good enough to spot a 4 nice difference. The story I was given was that it was special ordered by AT&T to work in the rural areas. I have a Dana 70 dually rear but what to do with the extra 4 inches of wheelbase?
Old 09-28-2013, 01:11 PM   #7
B_derK20
Here is the truck with the utility box on it. I hope I didn't just waste a bunch of money on something I can't use...
Old 09-28-2013, 02:13 PM   #8
donut
donut's Avatar
SRW? you may be fine, I don't remember the dimensions though. Most times a person refers to a cab and chassis, it's dual rw.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 09-28-2013, 02:33 PM   #9
B_derK20
Yes, it's definatly a SRW. I really hope that's the case but if there's ever a rare /odd thing I'll be the first to find it. I hope this time is the exception. The seller keeps telling me it's an '88 but I didn't think there was a standard cab SWR V30 in '88 so I'm assuming it's an '87.
Old 09-28-2013, 03:13 PM   #10
willett
Another Day, Another Dollar
willett's Avatar
Flat deck!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-28-2013, 03:52 PM   #11
Phillip Pennartz
so when it was mentioned that the c & c rear ends were narrower than regular rear ends was that because it was assumed that it was a dually or are c & c srw rear ends narrower than regular truck rear ends?
Old 09-28-2013, 04:30 PM   #12
B_derK20
I'd love to flat bed it but I have no cash left over and no fab skills. If I understand correctly rear axle width is the same as any K10 or K20 but because it's a v30 the spring perches are closer together because of different hangers on 1 tons. Right?
Old 09-28-2013, 05:09 PM   #13
Jimbo*
Correct; spring perch dimension is different than 10 or 20, but WMS (wheel mounting surface) is the same.
Jimbo* is offline   Reply With Quote
Old 09-28-2013, 06:28 PM   #14
B_derK20
Donut brings up a good point. Was there ever such a thing as a SRW c & c?
Old 09-28-2013, 08:15 PM   #15
GM72K10
Next!
GM72K10's Avatar
Yes, CUCV M1031s are such an example, the 3rd digit in the serial number would be a "B" signifying a C and C, but its still a pickup frame. SRW C31003s could also be ordered back during the square body era, thus you could get a 9 foot SRW utility body. You had to special order "Dual Rear Wheel" delete. We had some of those at work, the "car salesmen only" of that era had no idea what you were talking about lol.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 09-28-2013, 09:05 PM   #16
donut
donut's Avatar
Good to know. I do know that there were odd vehicles for utilities and railroad, didn't know they could be ordered C+C. Though if I thought about it, if they all came as pick-up's, the dealership would have a pile of old beds laying around.
Old 09-29-2013, 01:05 AM   #17
andrewmp6
That truck might not be a c&c it could be a normal 1 ton pickup,Is there a way to tell by the vin ?
Old 09-29-2013, 06:47 AM   #18
GM72K10
Next!
GM72K10's Avatar
I think the confusion is between model numbers. ANY model number could be ordered as a cab and chassis. The NON pickup models that are cab and chassis are C/K 31003 (135.5 inch wheel base) and C/K 31403 (159.5 inch wheel base) IN the vin if The third digit i is a "B" or a "D" just meant "incomplete truck".
86 K30 CUCV M1028A1
Old 11-04-2013, 08:27 PM   #19
B_derK20
Bringing this back from the dead...
I got the truck home and it's as I feared. It's a 135.5 wheelbase so it's 4 inches longer than a normal pickup. It's also an. '88 which I didn't think existed. (One ton single cab 4wd).
Is there anyone who has tried putting a bed on one if these? I don't have the money or skill to make or buy a flatbed and this truck is an absolute brute that's too good to part out.
Old 11-05-2013, 07:04 AM   #20
GM72K10
Next!
GM72K10's Avatar
This is what it will look like if you put a bed on that truck with out frame modifications.
86 K30 CUCV M1028A1
Old 11-05-2013, 07:53 AM   #21
BigBlocksRule
Is that a Dana 60 up front?
C&C aren't nearly the PITA for squares as the next generation where the General completely changed frames and only a work bed will fit on a C&C and vice versa.
BigBlocksRule is offline   Reply With Quote
Old 11-05-2013, 08:22 AM   #22
Keith Seymore
Keith Seymore's Avatar
Well said.
Just to finish your thought the "pickup length" version would be a C/K 309 03.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-05-2013, 11:03 AM   #23
manimal
manimal's Avatar
you could stretch a pick up box and create a square version of a Longhorn!(almost)
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-05-2013, 12:05 PM   #24
manimal
manimal's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=541824
-Lance
Old 11-05-2013, 01:51 PM   #25
B_derK20
Hmm. I could live with that look. The gap isn't as bad as I imagined it would be. I wish I had the skills needed to lengthen the bed but at this point I just can't.
Yes that is a Dana 60 in the front. That's why I got the truck was because of the way it was built. Dana 60, 14ff rear, 4 speed with hyd clutch , hydroboost and fuel injection. All the best pieces gm had to offer IMHO.
So the bed I have just just sit on the frame same as a regular truck except for a 4" gap right ?
Can anyone look at my spid and see if it has any other interesting options? I still don't believe this is an ' 88 but all the tags say it is.
