Old 09-28-2013, 08:21 PM   #1
Shak
Shak's Avatar
Rear End Choice
I have an opportunity to pick up a 94 Firebird rear end, 3.42 gears, limited slip, with disc brakes, for about $175 dollars, for my 51 AD project. I believe it is just over 60", which is what I think the stock length rears are. Any thoughts on this choice? If not, what would be a good choice, keeping ease in finding and reasonably priced in mind. My truck came with the wrong rear end, with all sorts of issues. I'm kind of new to this, so any advice is appreciated. Thanks.
Shak is offline   Reply With Quote
Old 09-28-2013, 09:47 PM   #2
xaircav
xaircav's Avatar
Re: Rear End Choice
The most common rear AD owners use (me included) is a Nova/Camaro 8.5" 10 bolt from 70's era cars. Several venders sell install kits to bolt up to the old springs. The Firebird rear you contemplate has a 7.625 ring gear. 8.5" 10 bolts are a dime a dozen, strong and have a lot of after market support. I got my mine for $50
xaircav is offline   Reply With Quote
Old 09-28-2013, 10:20 PM   #3
mr48chev
mr48chev's Avatar
Re: Rear End Choice
i'd follow what zaircay said and go with a second generation Firebird, Camaro or Nova rear end works pretty well.
Over the years I have had a number of rear ends in my 48.
I started with a 61 Chev Impala rear end with all of the brackets cut off and pads welded on. Then a 67/8 Camaro rear end that I ran for quite a while. I rebuilt the truck from the ground up and used a 65 Impala 12 bolt posi that actually fit quite well. It was a bit wide for the 10 inch wide Crager Mach 8 wheels and N-50 14 tires I was running though. Then back to a 70 something Nova rear end that is under it now. The Nova doesn't give much room between the tires and the bed sides unless you run reverse (negative offset) rims though.
My ongoing truck projects:
Old 09-28-2013, 11:57 PM   #4
Shak
Shak's Avatar
Re: Rear End Choice
My intention is to run a four link suspension with coil overs, and junk the existing spring set up. Does this change anyone's mind as to my rear end choices?
Old 09-29-2013, 11:56 AM   #5
_Ogre
_Ogre's Avatar
Re: Rear End Choice
i used an 86 trans am rearend in my 58 truk, same width as the one your looking at.
rear disc, posi, 3.27 gear, cost me $200. it fits well. tire burner w/ gas mileage
the parking brake feature is junk on mine. i think they changed that after 92.
the installation ''kit'' consists of spring pads, a plate and u-bolts. bought mine at a trailer supply for $29.
go for it
shop air compressor timer
Old 09-29-2013, 11:02 PM   #6
miknjan
Re: Rear End Choice
I picked up a posi/disc rear end from a 79 TransAm.. Fits perfect, Im using a 4 link rear end as well.
DV8
miknjan is offline   Reply With Quote
