09-30-2013, 09:08 PM | #1 |
2003 Chevy s10 4.3 died at intersection
My truck just died at intersection, try jump start it cranks but won't start. Would a bad alternator cause this?
Posted via Mobile Device |
09-30-2013, 09:32 PM | #2 |
Re: 2003 Chevy s10 4.3 died at intersection
Did the battery die? Reason for the "jump start"?
Check for spark, If none found.....Check the distributor cap for a missing button & a hole blown through it. Check fuel pressure, 60-66 is spec. |
10-01-2013, 07:39 AM | #3 |
All the lights starter everything just died. I thought it was the alternator so I had it checked by autozone they said it was fine.
10-01-2013, 09:20 PM | #4 |
Check the battery terminals/connections.......Not just look at them, Take them off & disassemble them, Clean them real good & see what happens.
10-01-2013, 10:35 PM | #5 |
I finally figured it out, I ended up having a bad battery and a bad fuel pump. Replaced the fuel pump and battery and back on the road today. Thanks for the help I really appreciate it! It just goes to show sometimes we can have two or more problems and not even realize it. Always keep an open mind to tracking down a problem. By the way i did clean all of my connections and added anti-oxidation lube to the connections for a more reliable connection. Thanks again!
