Old 09-16-2013, 04:56 PM   #1201
Ta2Don
Ta2Don's Avatar
Re: Not Another Rebuild Thread....
Happy Belated BDay & God Bless...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 09-16-2013, 08:03 PM   #1202
McMurphy
McMurphy's Avatar
Originally Posted by Ta2Don View Post
Eagerly awaiting Pics...
Sounds like you may have had a bit of fun with the newest Toy!!!
Indeed, it is fun !! I hope I can get those photos !
Originally Posted by Low Elco View Post
Happy birthday! Old guys (and trucks) rule! Hope you charged 'em, maybe at least one of these trucks we mess with will earn its keep!
One truck owner stashed a half rack of Alaskan Summer Ale in the truck cab the next morning, and the other truck owner has promised a shank of moose meat for the freezer !!
Originally Posted by Jmorales3181 View Post
Happy 50th buddy. Hope you had a good time
Originally Posted by Jeff La View Post
Happy 50th, hope you had a good day
It was a beautiful day weather-wise... that is good enough for me.
Originally Posted by jlsanborn View Post
Glad to hear you're putting the tow truck to work! Anxious to see some progress photos too.
Ok here you go buddy !!
Thank you Don !
So there I was with a Summit Parts Catalog and looking at Camaro Rear Sway Bars, remembering that some of you all have posted using these body type specific suspension parts.
What I did not commit to memory was the year ranges you guys use.
Nonetheless, I placed my order (yes I do that sometimes, eagerness overrides common sense in me some days ~LeSigh~).
This is what I got in the mail, and what I did to adapt it to my build.
In order to mount this I had to make the C-brackets, and have some 7/16" U-bolts made. Lucky for me there is a Transmission shop in Fairbanks that does this and it was an easy in-easy out task to get them.
I also had to cannibalize the radiator mount perches from my front clip donor to bolt them to the frame behind the rear axle to give my sway bar arms something to mount on.
Name:  28jul13 Rear Sway Bar (1).jpg
Name:  28jul13 Rear Sway Bar (4).jpg
Name:  28jul13 Rear Sway Bar (5).jpg
After I had everything for the adaption made, fabbed, and painted it was just a matter of bolting it up into place.
As you may guess, getting this sway bar to clearance the rear end access plate was the main priority and foremost in my mind.
Name:  28jul13 Rear Sway Bar (7).jpg
Name:  28jul13 Rear Sway Bar (9).jpg
On the happy side, it is a 7/8" bar, which matches the front sway that came off the donor Sierra. All in all my sense of OCD and balance were appeased.
I got this done just days before I went home on Leave for the month of August, and didnt have time to post it before bugging out.
Since then I have reattached the brake lines and bled them as stated the other day.
The bottom line to this is I must remember to not order parts untill I am 100% certain of all needed information. Though I must admit the closer I get to finishing this, the fewer parts orders I am making these days....
Thanks for looking guys, and if any of you spot a problem or possible hang up please point it out to me. You may have forgotten; but I am reminded daily that this is the first time I have done some of this stuff !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 09-16-2013, 09:36 PM   #1203
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Hmmmm.
Murph, I don't know how to tell you this.....But, from an observers standpoint, i don't think that this is going to work as you had planned.
I don't want to seem like a stick in the mud, but the entire idea behind the ANTI-swaybar is contingent on the force needed to twist the bar to resist body-roll in cornering.
That being said, the ANTI-swaybar needs to be mounted parallel to the ground to achieve as much twist as possible during cornering to attempt to force the inside wheel to be level with the outside wheel, thus keeping the vehicle somewhat level.
The way that it is mounted in the photos, very little twist will occur during cornering, resulting in the body roll of the vehicle easily overcoming the force needed to twist the bar, rendering the ANTI-swaybar virtually useless....My opinion from an engineering standpoint.
Modges'66 is offline   Reply With Quote
Old 09-16-2013, 10:04 PM   #1204
McMurphy
McMurphy's Avatar
Originally Posted by Modges'66 View Post
Hmmmm.
Thanks for the input Modges...
Here are the photos I used as a reference; it seems to be a common method of mounting and I thought I got mine as close to this as possible....
Name:  1984 Z28 rear swaybar 1.jpg
Name:  1984 Z28 rear swaybar 2.jpg
Name:  1984 Z28 rear swaybar 3.jpg
Name:  1984 Z28 rear swaybar 4.jpg
Name:  1984 Z28 rear swaybar 5.jpg
These photos were shamelessly lifted (pilfered) from RockTonka's build found here: http://67-72chevytrucks.com/vboard/s...507111&page=12
Post #285
Any suggestions on how I can fix mine?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 09-16-2013, 10:24 PM   #1205
Modges'66
Modges'66's Avatar
Murph,
The drag links need to be TOTALLY vertical or perpendicular to the swaybar when the vehicle is sitting on the ground.
As you can see in the second photo that you just posted, the links are, which allow the greatest leverage to attempt to flex the bar as much as possible with the least amount of travel.
PM me and we can discuss over the phone tomorrow.
Old 09-17-2013, 07:34 AM   #1206
BOXER957
BOXER957's Avatar
A noble effort, but yes talk to Modge over the phone and he will give you a better understanding of how they work. From the picture it looks to me like your kit will work, you just need to flip your bar around and it looks like it will work.Look at the pictures of the other guys truck, you'll notice what I'm about to tell you. Mount the sway bar on top of the rear housing, flip it around so the arms go towards the rear of the truck and the bar sits in front of the diff. with the arms travelling rear, remount your vertical links. Try to keep the links as close to a 90% angle as possible, should be easy beans. Good luck, we'll be waiting for an update on both installation and difference in ride quality.
Nice EASY project, no problem....until I get home why is that? My build: http://67-72chevytrucks.com/vboard/s...d.php?t=595078
BOXER957 is offline   Reply With Quote
Old 09-18-2013, 08:11 AM   #1207
Low Elco
Thanks for saying it, Modge. I didn't wanna be the one to pee on the parade. No biggie Murph, ya got the right parts, just need a bit of re-orienting.
Low Elco is offline   Reply With Quote
Old 09-30-2013, 09:38 PM   #1208
McMurphy
McMurphy's Avatar
Sorry about the lack of updates...
I was so discouraged by the previous comments that I decided I could no longer compete with Modges, Boxer, and LowElco, so I sold the truck and all my tools and have taken a vow to never turn a wrench again.
To all my faithful supporters.....well thanks.
Meh....just kidding guys.
I was staring at my front sway bar like Modges suggested and I competely understand what he was trying to tell me now about my rear one.
Sadly I have not undertaken the task of fixing it yet.
In classic Me tradition, I had already started my next phase by the time I posted those pics, so now I have to finish this before I can go back and fix that.
But for those who have been keeping score, you all know what tomorrow is.....
So big post from me tomorrow, just contemplating photos, or video?
Anyways just to let you all know I had not abandoned you, or my truck!!
Thanks for reading
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 09-30-2013, 09:55 PM   #1209
Ta2Don
Ta2Don's Avatar
Big Update Coming!!!
Video be my VOTE!!!!
DON
Proverbs 27:17
Old 10-01-2013, 01:19 AM   #1210
markeb01
Senior Enthusiast
markeb01's Avatar
Holding on standby!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-01-2013, 02:07 AM   #1211
KroAutomotiveInc
KroAutomotiveInc's Avatar
looking real nice man that thing is going to be one smooth ride cant wait for the update!
KroAutomotiveInc is offline   Reply With Quote
Old 10-01-2013, 02:58 AM   #1212
jlsanborn
jlsanborn's Avatar
Anxious to see what you've got in store! The sway bar should be an easy fix, just gotta shift a few things around.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-01-2013, 09:58 PM   #1213
McMurphy
McMurphy's Avatar
How about both photos and a video ??
Originally Posted by markeb01 View Post
Holding on standby!
Thank you sir, hope I do not disappoint !!
That would make two of us hoping this is going to be a worth while ride man !
Here you go my friend, hope you enjoy !!
So here we are again, 01 October, start of a new fiscal year, and 2 years since I introduced myself to this community by starting this build thread.
My my my how the time flies eh??
Again like last year, as much for you guys as for me, it is time to reflect on where I started and where I am at now.
What follows here are a few side by sides that should represent some of that progress...the good, bad, and the ugly.
At the end of it, I will supply a video that will be more progressive in nature, and of course subject you all to some more in my musical tastes.
Sit back, relax, and I hope you enjoy the show !
Name:  22sep11 1966 Chevy Stepside (10).jpg
Size:  69.7 KBName:  01oct13 (2).jpg
Name:  22sep11 1966 Chevy Stepside (8).jpg
Size:  64.8 KBName:  01oct13 (21).jpg
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-01-2013, 10:13 PM   #1214
McMurphy
McMurphy's Avatar
Next set:
Name:  22sep11 1966 Chevy Stepside (11).jpg
Size:  59.4 KBName:  01oct13 (1).jpg
Name:  04oct11 pass_side door before.jpg
Size:  43.4 KBName:  23may13 door panels (3).jpg
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-01-2013, 10:28 PM   #1215
McMurphy
McMurphy's Avatar
Round 3....
Name:  22sep11 1966 Chevy Stepside (12).jpg
Size:  63.8 KBName:  01oct13 (3).jpg
Size:  16.7 KBName:  01oct13 (19).jpg
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-01-2013, 10:40 PM   #1216
Jmorales3181
Jmorales3181's Avatar
big difference! Need a full walk around!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 10-01-2013, 10:41 PM   #1217
McMurphy
McMurphy's Avatar
Last set....
Size:  67.6 KBName:  01oct13 (4).jpg
Name:  09oct11 gauge cluster.jpg
Size:  45.2 KBName:  01oct13.jpg
.....for now !!
Thanks for looking guys.... my next post should have a video in it for you!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-01-2013, 10:45 PM   #1218
Ta2Don
Ta2Don's Avatar
plus I'm looking foreword to the VIDEO...
DON
Proverbs 27:17
Old 10-02-2013, 02:49 AM   #1219
likaroc13
Rollin' Old Skool
It has come a long way for sure! Keep up the good work.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-02-2013, 04:36 AM   #1220
BOXER957
BOXER957's Avatar
Fantastic! From where you started to where you are, you have absolutely every reason to be proud! Especially considering your location and the climate you have to deal with. I wish I had thought to do a walk around set of pics so I could have a before and after comparison. Again Great job, both on the truck and the pics. dtw out of all the pics you've ever posted, the one where your wife is out there in the blistering cold junkyard in 100 feet of snow trying to take out the bronco seat...She's a keeper! Kudo's to you my friend on all points. I think we need to see some whole truck walk around shots
Old 10-02-2013, 10:04 AM   #1221
Jeff La
Looks great, slowly buy surely getting there
Jeff La is offline   Reply With Quote
Old 10-02-2013, 11:48 AM   #1222
McMurphy
McMurphy's Avatar
Here you go, it is late due to crappy internet up here....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 10-02-2013, 11:56 AM   #1223
1963c-10
1963c-10's Avatar
Good job McMurphy....your getting closer with ever job done.
1964 Short bed trailer
Old 10-02-2013, 12:08 PM   #1224
jlsanborn
jlsanborn's Avatar
What a great reflection! You have done a ton of work Murph. I did like the "Remove the heater cord" note on the old cluster tho. My son has a similar note about headlights on his truck What's on the adgenda? When we gonna go for a drive?
Old 10-02-2013, 12:43 PM   #1225
Ta2Don
Ta2Don's Avatar
Amazing transformation Murph!
My 2 year mark will be April 2014... No where near the progress you've made...
Congrats!!!
...and the Joe Satriani piece...
DON
Proverbs 27:17
