Old 10-02-2013, 09:12 PM   #1
Moloko
Hoarding Rusty Objects
Moloko's Avatar
Brake Issues - 85 K20
So I bought this 85 K20 back in June that was left at a local shop due to it's brake lines rusting out. I replaced the master which was leaking, all the brake lines, rear wheel cylinders, and front calipers. After I bleed the brakes (both normal, and with a Phoenix reverse bleeder) It has pedal when the truck is off, and will pump up and hold pressure. When I turn the truck on the pedal goes right to the floor, and the prop valve trips to the front. I went as far as to re-change the rear brake line again tonight thinking it was leaking at the junctions, and it still trips the valve the second you touch the brake pedal.
Could the prop valve be bad? I've never heard of it, I've only heard of people changing them when they won't re-center after tripping, but I've been taking it off and manually pushing it back with a pick each time.
1985 Chevrolet K20 Silverado
1994 GMC Yukon
Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks
Moloko is offline   Reply With Quote
Old 10-02-2013, 09:26 PM   #2
86c20
86c20's Avatar
Re: Brake Issues - 85 K20
last time i had that it was the rear wheel cylimders. and that was on a 86 c20 with the heavy breaks
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 10-02-2013, 09:30 PM   #3
Moloko
Moloko's Avatar
Bad as in leaking? Because I changed them, and it had this problem before and after changing them.
1994 GMC Yukon
Old 10-02-2013, 10:37 PM   #4
geezer#99
geezer#99's Avatar
Did you keep the reset pin held in while you bled the brakes?
Old 10-03-2013, 05:00 AM   #5
donut
donut's Avatar
x2, and if you have power brakes, unplug and cap the vacuum the booster, see if it still does it.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-03-2013, 06:41 AM   #6
Moloko
Moloko's Avatar
No, I reverse bled them from the wheels in.
1994 GMC Yukon
Old 10-03-2013, 09:31 AM   #7
geezer#99
geezer#99's Avatar
Could you take the time to explain 'reverse bled'?
Old 10-03-2013, 11:08 AM   #8
Moloko
Moloko's Avatar
I have a Phoenix reverse bleeder. It has a pump that pushes the fluid from the bleeder screws at the wheels back up to the master. It pushes all the air out infront of the fluid.
1994 GMC Yukon
Old 10-03-2013, 01:17 PM   #9
86c20
86c20's Avatar
try adjusting them way up that was the only otherthing that i ran into. and i mean way up
Old 10-03-2013, 01:40 PM   #10
geezer#99
geezer#99's Avatar
Thanks!
Your prop valve likely has a residual check valve for the rear brakes.
Do you get air bubbles in the m/c on the rear brake side?
Old 10-03-2013, 02:25 PM   #11
Moloko
Moloko's Avatar
No, no air bubbles from any wheels.
1994 GMC Yukon
Old 10-03-2013, 02:40 PM   #12
Moloko
Moloko's Avatar
Would this pressure valve cause the issues? I did notice a series of rubber diaphrams inside the prop valve when I took it apart.
1994 GMC Yukon
Old 10-03-2013, 02:56 PM   #13
geezer#99
geezer#99's Avatar
You should of got bubbles back into the master. Air has to go somewhere. Even while bench bleeding the master you get air bubbles up from the piston return hole.
Maybe you need to depress the pin on the prop valve, lock it down and rebleed the system the conventional way. From the master to the furthest cylinder and back to the master.
Old 10-03-2013, 03:12 PM   #14
Moloko
Moloko's Avatar
No I mean it no longer has bubbles when I bleed it, all the air is out of the system
1994 GMC Yukon
Old 10-03-2013, 04:44 PM   #15
ozbowhunter
What reset pin ????
ozbowhunter is offline   Reply With Quote
Old 10-03-2013, 04:47 PM   #16
ozbowhunter
will this fix my brake light problem on the dash ?the reset pin when I bleed the brakes (sorry not trying to hijack the post)
Old 10-03-2013, 06:50 PM   #17
Moloko
Moloko's Avatar
There is a button on the driver side of the valve, but from what I can tell it will only reset if the valve has tripped to the rear (blocking off the front brakes). I don't see how it will do anything for the valve tripping to block the rear brakes.
1994 GMC Yukon
Old 11-09-2013, 09:04 AM   #18
Moloko
Moloko's Avatar
Update, I put on another used prop valve, and after about 5 minutes of bleeding the brakes were fine. This has been fixed for two weeks or so, just havn't gotten around to updating everyone.
1994 GMC Yukon
