Old 10-03-2013, 06:34 PM   #1
blazer-k5
blazer-k5's Avatar
1960 1 ton?
I found this 1960 1 ton. for $800. I'm curious how it is a one ton with split rims and a single rear axle? It says C30 and that its rated at 10000 lbs. It also has a leaf spring in the back and a bumper. The flat bed is off of a ford...so that doesnt help me. Its a inline six with a 4SPD.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 10-03-2013, 06:39 PM   #2
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
I guess the wheels and the single axle is throwing me off...Shouldn't a 1 ton be a dually?
1960 235 4SPD C30
Old 10-03-2013, 07:32 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1960 1 ton?
Not always a dually, they can be single wheel
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is online now   Reply With Quote
Old 10-03-2013, 07:48 PM   #4
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
Thanks... I probably sounded crazy. Not many of these rolling where I'm at. I have nothing to compare it to. Even more so that it has split rims..
1960 235 4SPD C30
Old 10-03-2013, 07:52 PM   #5
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 1960 1 ton?
It also probably had a 9 Ft Pick-up Bed on it as well, unless it had a utility body or another type of special bed on it. If you measure the Wheel Base, we could tell for sure.
To confuse us all even more, they also made a C-20 3/4 Ton Dual Wheel truck as well in the later years.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 10-03-2013, 07:55 PM   #6
C10 - C90 Bill
Re: 1960 1 ton?
Another way to look at your truck is that you have an extra Heavy Duty 3/4 Ton that is rated for 10,000 Lbs. The Wheels are most likey 16 Inch.
GMC 9500 Fan
Detroit Diesel Fan
Old 10-03-2013, 07:57 PM   #7
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
HA ...Well am I right that the wheel base is either like 133 or 137 inches?
Im kinda guessing your on the money with a pickup bed. I've just never seen another.
Im thinking about leaving the ford flat bed on there and saying "The ford didnt make it ,but it had one good part on it."
1960 235 4SPD C30
Old 10-03-2013, 07:59 PM   #8
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
Like a HD 3/4?...it does say C30 on it. At first I thought the old farmer that had it switched all the parts off of another to a good frame, but its all to good looking for that. ONly thing home made was flat bed brackets.
1960 235 4SPD C30
Old 10-03-2013, 08:00 PM   #9
C10 - C90 Bill
Re: 1960 1 ton?
Probably 133 which should be a 9 Ft Bed.
GMC 9500 Fan
Detroit Diesel Fan
Old 10-03-2013, 08:02 PM   #10
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
I'll give her a measure...
1960 235 4SPD C30
Old 10-03-2013, 08:04 PM   #11
C10 - C90 Bill
Re: 1960 1 ton?
Like an "Extra" Heavy Duty 3/4 Ton. ...I'm just saying.
It's correct. Your truck is supposed to say "C-30".
GMC 9500 Fan
Detroit Diesel Fan
Old 10-03-2013, 08:33 PM   #12
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
Its 133. Thanks for the help though because the info i was finding did not all add up to many people not enough fact.
1960 235 4SPD C30
Old 10-03-2013, 11:48 PM   #13
Captainfab
60-66 Nut
Re: 1960 1 ton?
That C30 should also have coil springs up front instead of the torsion bars typically found on the '60-'62 C10's and C20's.
Old 10-04-2013, 01:36 AM   #14
jtrichard
Re: 1960 1 ton?
captain why would it have coils? i know they used torsion bars on 2 1/2 tons in 60
jtrichard is offline   Reply With Quote
Old 10-04-2013, 10:25 AM   #15
MitchFloyd
MitchFloyd's Avatar
Re: 1960 1 ton?
I'm curious about the I-6. Is it a 235 or a 261? I'd think that with a 1ton that it'd be a 261. Get the casting numbers and we'll check it.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 10-04-2013, 10:59 AM   #16
1963c-10
1963c-10's Avatar
Re: 1960 1 ton?
Cool looking truck either way.
1964 Short bed trailer
Old 10-04-2013, 11:02 AM   #17
TJ's Chevy
TJ's Chevy's Avatar
Re: 1960 1 ton?
Nice rig! 235 I presume?
Old 10-04-2013, 11:46 AM   #18
factorystock
factorystock's Avatar
Re: 1960 1 ton?
In 1960, this was known as a "Apache 30". 1 tons were available with single wheels all the way around as well as the dual wheel version. Does not have front hub adapter, so this was a single wheel when new. The lock ring wheels on front (they are not split rims) do not have clips, they have bumps, so they are not the original wheels to the truck. All Chevy trucks except 4WD, used torsion bar front end in 1960. 235 was the only 6 offered in 1960 in 10 thru 30 series. 261 was not a standard option till 1962 on 10 thru 30 series. Things get changed over the years, so you really never know what 6 is under the hood. One tons are geared very low ( 5.13), good for hauling heavy loads around town or farm, but not freeway friendly.
factorystock is offline   Reply With Quote
Old 10-04-2013, 11:49 AM   #19
MitchFloyd
MitchFloyd's Avatar
Re: 1960 1 ton?
Thanks factorystock for the info. I knew the 261 was a upgrade but didn't know it wasn't available until 1962.
'62 Chevy K10
Old 10-04-2013, 12:13 PM   #20
MitchFloyd
MitchFloyd's Avatar
Re: 1960 1 ton?
In 1954, a 261-cubic-inch (4.3 L) truck engine was introduced as an optional Jobmaster engine for heavy-duty trucks. This engine was very similar to the 235 engine, except for a different block casting with a larger piston bore of 3.750” or 95.25 mm, two extra coolant holes (in the block and head) between three paired (siamesed) cylinders, and a slightly higher lift camshaft. This engine was offered as a step up from the 235 starting in 1954. It was offered in parallel with the GMC V6 engine in 1960 until 1963, when it was discontinued. The 261 USA truck engine had mechanical lifters and was available from 1954 to 1962.
The 235 and 261 truck engines were also used by GMC Truck of Canada (GMC truck 6-cylinder engines were also used in Canada). The 1955–1962 Canadian full-size Pontiac car had an optional 261-cubic-inch engine that had hydraulic lifters. This engine was not sold in the USA, but was very similar to the USA truck 261.
'62 Chevy K10
Old 10-04-2013, 01:37 PM   #21
jtrichard
Re: 1960 1 ton?
Nice to see someone else that's knows they are NOT split rims that they are lock ring.... I did not catch the lack of clips good call there ...as for the "1 ton" tare weight of that truck is more like 2 ton it should weight in at under 5000 and the gross as shown on the tag is 10000 = net of 5000lbs.= 2 ton ..i have a 63 C20 with net ratting of about 1 1/2 ton
Old 10-05-2013, 01:15 AM   #22
Captainfab
60-66 Nut
Re: 1960 1 ton?
I don't know the details as someone like factorystock or MitchFloyd, but I have seen a couple C30's from the '60-'62 year range that had coil springs up front. Admittedly they may not have been 1960's but they were in that year group.
Old 10-06-2013, 07:16 PM   #23
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
Thanks I do like the truck. It is a 235. It does have torsion bars up front.
The rings on the wheels do have one split. So these arnt actual split rims? they are just bump rings? Never even hear of those.
1960 235 4SPD C30
Old 10-06-2013, 09:04 PM   #24
C10 - C90 Bill
Re: 1960 1 ton?
You and many others may already know this, but Front Coil Springs started in '63. It could be possible that someone put a '60-'62 Front Clip on a '63. The Windshield would also be the same as the early models.
GMC 9500 Fan
Detroit Diesel Fan
Old 10-06-2013, 09:19 PM   #25
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton?
Heres my vin in case yall were interested OC364K122279 i know some like to break down the vins.
1960 235 4SPD C30
