Old 10-03-2013, 10:16 PM   #326
coulter
coulter's Avatar
Re: my build thread
thats good news man!!! looking forward to seeing some new updates
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 10-04-2013, 09:56 AM   #327
Ta2Don
Ta2Don's Avatar
Re: my build thread
Scoring a short wide bed!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 10-16-2013, 08:10 PM   #328
sams60gmc
sams60gmc's Avatar
Re: my build thread
set the bed on there today so i can start planning mounts... waited a long time to see this...
Ran into a problem with the axle width tho...The tires rub at the body line after I trimmed all the inner bed away... Not sure what to do...
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 12-10-2013, 10:48 PM   #329
sams60gmc
sams60gmc's Avatar
Re: my build thread
well ive decided for a new rebuild... i decided i wont be happy until i build a whole new tube frame. I want something completely custom and to get rid of the factory crossmember. I want to do new tube lowers to match my uppers and maybe be able to move my rack to be able to set my motor a bit further. Also going with 3/16 wall tube this time to make things a littler more heavy duty because I want to have the option to tow a trailer. It will still have the 2'' body drop and 3'' Z built in. Maybe a bigger notch in the back for the option to go lower over bigger wheels.
Old 12-21-2013, 09:03 PM   #330
sams60gmc
sams60gmc's Avatar
Re: my build thread
Starting on the front crossmember. It's built out of 1.5 1/4 wall dom. I'll finish this then build a frame around it.
Old 12-21-2013, 10:17 PM   #331
TJ's Chevy
TJ's Chevy's Avatar
Re: my build thread
Looks cool!
Old 12-24-2013, 05:45 PM   #332
sams60gmc
sams60gmc's Avatar
Re: my build thread
Got some time to work on this thing today. I've got a set of mock up rails done that I'll build my whole front suspension and steering off of. Machined my cross shafts today and got some of the crossmember tacked up.
Old 12-26-2013, 05:10 PM   #333
creep
Registered Loser
creep's Avatar
Re: my build thread
Good to see some work on that thing. Serious skills, man.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 12-28-2013, 02:49 PM   #334
sams60gmc
sams60gmc's Avatar
Re: my build thread
got the crossmember all welded up yesterday and stuck it in the mill to make sure everything was flat... it moves the suspension mounting points up about 3'' and the lower arms in about an inch per side. now ill start working on the upper mounts and lower arms.
Old 12-28-2013, 08:10 PM   #335
sams60gmc
sams60gmc's Avatar
Re: my build thread
one more
Old 01-01-2014, 12:56 PM   #336
coulter
coulter's Avatar
Re: my build thread
wow i cant believe nobody replyed to that!!! killer work man!! i really wanted to try that but i dont think my fabs skills are quite on that level yet. Sick work man keep it up
Old 01-01-2014, 03:51 PM   #337
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thank you man, it was actually pretty simple, just a few fancy tools and a ton of measuring...
got some more work done, on to lower arms now.
Old 01-01-2014, 09:41 PM   #338
laynrockers
laynrockers's Avatar
Re: my build thread
Just read through the whole build, Great job. You definitely got skills brotha!!
laynrockers is offline   Reply With Quote
Old 01-02-2014, 01:07 AM   #339
Bomp
Bomp's Avatar
Re: my build thread
You definitely changed direction to a Seriously Intense build. Dig it!
Bomp is offline   Reply With Quote
Old 01-03-2014, 11:22 PM   #340
Jmorales3181
Jmorales3181's Avatar
Re: my build thread
Nice work!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 01-04-2014, 01:31 AM   #341
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thats what its all about BOMP!! thanks!
Old 01-06-2014, 12:27 AM   #342
sams60gmc
sams60gmc's Avatar
Re: my build thread
fairly un productive weekend, not mych to report, just been working with scale drawings of the front suspension trying to figure out control arm lengths to end up with the best caster camber throught the suspension travel. Also did a quick scale sketch of my current frame, ill make another drawing on top of it with revisions to make sure everything will work...
Old 01-12-2014, 02:20 PM   #343
Bomp
Bomp's Avatar
Re: my build thread
What size of tubing stock are you going to use on the a-arms?
You have got my full attention. I totally dig what you're doing!
Old 01-12-2014, 02:32 PM   #344
sams60gmc
sams60gmc's Avatar
Re: my build thread
thanks bomp. the uppers i made a few years ago out of 1 1/4, 1/4 wall, if i need to re do those again they will be 3/16 wall. the lowers are going to be made out of 1 1/4 1/4 wall most likely, as i already have a bit of it around left over from my uppers...
hopefully this week i can get around t turning my ball joint cups so I can start them..but I may have to put them off for another week,
I recently built a cage for a friends RZR in trade for a 55 6? plymouth plaza. the car is pretty neat, all factory trim and hub caps and a factory V8 wich I read is pretty rare, so ill hopefully get that this week, planning on just getting it running and throwing new tires on it and cruising it daily.
Here are some pics, it was the first cage ive ever built, turned out nice i think, and i even tigged most of it.
Old 01-17-2014, 12:14 AM   #345
sams60gmc
sams60gmc's Avatar
Re: my build thread
well i finally did a final revision of the backhalf to my frame and picked up steel today... cant wait to knock it out this weekend... also been spit shinin the Plymouth a little since getting it towed home
Old 01-17-2014, 12:52 AM   #346
Bomp
Bomp's Avatar
Re: my build thread
Woooo Hooooo another addition to the collection!!!!
Totally dig the mapped out plan for the back half.
Old 01-17-2014, 11:43 AM   #347
Jeff La
Re: my build thread
Man you guys have some really great brains to lay out all this and the patience to boot. Along for the ride.
Jeff La is offline   Reply With Quote
Old 01-18-2014, 07:56 PM   #348
sams60gmc
sams60gmc's Avatar
Re: my build thread
Well i cut some tubing and threw these together last night and today. Turned out nice. I drilled them and plug welded internal fish plates to keep them nice and smooth. Fully welded them with the 251 Miller, then went back in and Tigged any small areas affected by the heat and smoothed them out. One rail is done completely, ground with 36-120 and then with a surface conditioning disc
Old 01-18-2014, 11:55 PM   #349
TJ's Chevy
TJ's Chevy's Avatar
Re: my build thread
Me thinks were gonna have ta start callin ya Mister Tube! LOL! Nice work so far!!! Looks forward to watching this build go! Hope all goes well! T.J.
Old 01-23-2014, 09:19 PM   #350
sams60gmc
sams60gmc's Avatar
Re: my build thread
Got the rear rails done and smoothed out, still contemplating building a frame table, but I know ill build more trucks on it so i guess i will start on one...
worked on a lower control arm jig today, still waiting on DOM for those to come into stock...
also threw together some threaded link ends. Building a wishbone 4 link with a bridge over the pumpkin...
enough talk. on to the pics...
