Old 10-05-2013, 09:13 AM   #1
blizno23
New Door Hinges
Hi all,
I have been lagging on my '71 stepside, so I decided to jump back in it full bore and strip everything down. I installed new door hinges, but now the doors have to be slammed shut with the force of Thor. Any ideas on how to get the doors to act nice? Sorry for my ignorance but this is buggin the hell outta me.
blizno23 is offline   Reply With Quote
Old 10-06-2013, 06:47 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: New Door Hinges
Sounds like they need to be adjusted outward.
It's trial and error there. Just be sure to move a little at a time because a slight movement makes a big difference.
Alot of patience helps too.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-06-2013, 10:26 PM   #3
blue694x4
Re: New Door Hinges
depends on the problem. If door is simply too tight move striker out, like mentioned previously. But my guess is that the door was adjusted to compensate for the bad bushings. The correct way to fix this is to remove the striker all togather and adjust to fit cab by itself. Then once you have the door fitting instal striker and adjust striker till door latches nicely. If you need to adjust door up or down that is a hinge adjustment.
The only other issue I've had with a door thats hard to close is aftermarket wheatherstripes that are to thick.
blue694x4 is offline   Reply With Quote
Old 10-06-2013, 10:32 PM   #4
blizno23
Re: New Door Hinges
Thanks guys, Ill probably just move the strikers. Its more than a quarter inch off so ill do that and see what happens. Ill post results.Thanks!
