Old 10-07-2013, 10:36 AM   #1
ls70918
lowering my 70 gmc
I've posted here before and got good answers from you all. With that in mind, you need to know that I am no mechanic. I can muddle my way through projects, but you may have to dumb your answers down for me.
So I have a 1970 2wd, 1/2 GMC Pickup that I'd like to lower around 2 to 2-1/2 inches in the front and level the back to match. I also want to change the front brakes to disc at the same time.
I've looked into drop spindles for the front, but what's the best way to lower the back and not screw up the ride, etc.? Also, what brand of brake conversion kit should I use?
ls70918 is offline   Reply With Quote
Old 10-07-2013, 11:23 AM   #2
mgkgmc
mgkgmc's Avatar
Re: lowering my 70 gmc
I would say check out Early Classic Enterprises. Probably have the most complete drop kits and brake kits. http://www.earlyclassic.com
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 10-07-2013, 11:59 AM   #3
jmorri34
jmorri34's Avatar
Ask away man, we were and are where you are at one time all of us. There are plenty of people on here that will be glad to help you. As for the back, it depends first of all if you have leaf or coils spring rearend. If its coils then Id say a good set of lowering coils would do the job for you. You shouldnt have to do much else unless you go with a really short spring and then you get into another whole ball of wax but if your only talkin 2 inches or so a set of springs should be all it takes. I am not sure on the leaf spring side maybe someone will chime in! good luck
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 10-07-2013, 02:18 PM   #4
c10Dream'n
c10Dream'n's Avatar
here's a side shot when i had 2" / 4" drop coils from CPP.
c10Dream'n is offline   Reply With Quote
Old 10-07-2013, 06:03 PM   #5
JointTech
JointTech's Avatar
thats only drop coils?
what size wheel?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 10-07-2013, 07:03 PM   #6
bovey
bovey's Avatar
Yes, for that amount of drop you can just do coils, both CCP and Early Classic will suit your needs. The ride is great and you'll have no issue with geometry. I did my first drop 15 years ago and was fine the AND the parts are way, WAY better now.
bovey is offline   Reply With Quote
Old 10-07-2013, 10:47 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Go with early classic as recommended above and then click on "project blank slate" in my signature below. On my 69 I installed an ECE 4.5/6" drop with disc brake upgrade and the install is documented in the build thread.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-08-2013, 10:29 AM   #8
ls70918
Thanks for the tips. "72" that link to you blank slate is exactly what I need.
Old 10-08-2013, 05:24 PM   #9
Tinkermc
Welcome to the Forum and you landed in a goood place here with us. Not the Allstste Good Hands but better.
Tinkermc is offline   Reply With Quote
Old 10-08-2013, 11:45 PM   #10
70 longbed
I did the 2/4 premium kit from ECE. I am not sure you need the pan hard bar when only dropping 4 in the rear, but it was suggested so I did it. It all goes together easily and I think that anyone with some knowledge of our trucks and the tools could do it.
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 10-08-2013, 11:53 PM   #11
haminator
haminator's Avatar
So you have rear coils then? Typically GMC's are rear leaf. I have a 72 Chevy w/leafs and want to drop the rear. I could put the axle on top of the springs but I'm afraid it might be lower than I want. Courious about your kit if its for leafs. You mentioned panard bar, leaf rear don't have panards.
haminator is offline   Reply With Quote
