Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-07-2013, 08:44 PM   #1
allons
Wheelbase lengths
I'm shopping for a 64-66 fleetside or a 64-66 suburban. I know the two w'base dims for the fleetside is either 115" or 127". What I have not been able to find is the w'base for suburban. Anybody got a source for the suburban w'base dimensions? Thanks!
allons is offline   Reply With Quote
Old 10-07-2013, 09:03 PM   #2
padresag
Re: Wheelbase lengths
only 115"
ron
padresag is offline   Reply With Quote
Old 10-07-2013, 09:34 PM   #3
allons
I would have thought that the subbie w'base would have been 127 or more. If the subbie has a w'base of just 115" then that must mean that I could use a swb pick up truck frame for the frame on the subbie, changing body mounts of course. Right?
Old 10-07-2013, 10:28 PM   #4
padresag
why not just use the frame that comes with the suburban
there are 3 different sets of frame brackets for body mounting that the pickup doesn't have and there is the rear frame extension.
ron
Old 10-14-2013, 03:52 PM   #5
crazyhenryj
Ron,
thanks for this info, I just picked up a 65 Burb and was thinking of moving the body over to a 71-72 SWB truck for the disc brake and 5 lug but with the added body mounts I will stay with stock frame.
crazyhenryj is offline   Reply With Quote
Old 10-14-2013, 03:58 PM   #6
cg285
everything you want to know:
http://gmheritagecenter.com/gm-herit...tion-kits.html
cg285 is offline   Reply With Quote
Old 11-17-2013, 07:08 PM   #7
GVDobler
GVDobler's Avatar
Originally Posted by crazyhenryj View Post
Ron,
Then the wheelbase will be 2" too long., and wider, but wider is easier to deal with.
The front assembly/crossmember will bolt on to the '65 frame then some 5-bolt rear axles an you're all set. Sounds easier than cutting down the '71 frame 2" and adding the correct body mounts.
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
