#26 |
Re: 67 C20 split rim/hub cap question
I see the clips come up on E-bay from time to time, listed as new and for our application. Who knows for sure if they are the same though?
#27 |
Good question, will have to remove clips from a period 8 lug rim ( if they all haven't been scrapped and sent to China by now) to find out for sure. The article on post #25 does not mention source for clips
#28 | |
Did you get any further with this? How is the preliminary fitment? Pretty close? Hopefully the wheel opening is too big rather than too small. Much easier problem to solve! |
#29 |
The fit is very nice, hubcap is flush against rim. There is a little side movement, maybe 1/4", but 4 clips should lock it into place. I'll be getting some clips in the near future. It seems the mounting location of the clips will be key.
#30 | |
![]() ![]() Where I screwed up was the depth of the clips. On these "nub" style wheels I couldn't get them tall enough with the ½" 10-24 screws I bought. I'm afraid if I space them high enough they will be too springy like little diving boards. Maybe I will address this the next time I am at the shop. That's as far as I got. These are freebys until I can get some Econoline wheels. The little ramps between the lugs should solve this issue, but without one to measure I can't be sure. Posted via Mobile Device Posted via Mobile Device |
#31 |
Finnally, made some progress. Looks like the 2006-2013 Econoline wheel is the ticket. You must use original clips from an 8 lug wheel. 1/2 ton or car clips that are repoped are too short. The clips need to be straighten out a bit to get them closer to the rim. A few light blows from a hammer did the trick. I installed the clips flush against the edge on the ramped up area. Hubcap snapped on firmly. I believe the weakest link is the screws, its hard to get them to stay tight. I would like to do a hot rivet, just like the way the clip type wheels were manufactured. Can this be done today? Are there businesses out there that will rivet the clips to these wheels?
#32 |
Another close up
#33 |
With hubcap installed. The offset looks just like the period '67 thru '68 16.5" wheel.
#34 |
Looks great! Why not just tack weld the screws behind the wheel? Do you just not want to see screws,when the hub caps are off? I'm sure there are businesses that could hot rivet those,or locate the rivets and I'm sure any welding shop could do the job.
What year Econoline wheels are w/o nubs and still SAE?
#35 |
The Niner
![]() Join Date: Nov 2010
I don't know what year the wheels went nubless (is that a word?) but they've been SAE the whole time.
I know, it makes no sense...
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#36 |
![]() Join Date: Apr 2011
I have a funny sidebar to this quandary...my '71 K20 originally came with 17" split rims, and I got ahold of 4 rims and tires from an E-350 to replace them, I believe in a past life they were on an ambulance.
Of course I didn't have hubcaps, but found some 80's style caps at a swap meet for about 10 bucks, so I thought I'd see if they fit. If not, they look good on the wall. I got them home and walked to the passenger side of the truck, when I discovered that the new wheels had no nubs for the caps. Bummed, the caps got hung up on the wall. I figured this must have been an ambulance with full Ford wheel covers. About a year later, I was checking tire pressures and I started on the driver's side of the truck. A light bulb went off when I noticed that the wheel I was looking at had nubs! I double checked the passenger side, and sure enough, two wheels have nubs (drivers side) and two wheel are nubless! (passenger side) So my truck currently has caps on one side and no caps on the other. Pleases both crowds! ![]()
1971 Chevy K20 350/SM465/NP205 |
#37 |
The bumpless 8 lug 16" Econoline wheel first came out in 2006 and still are used today. All these vans came with full wheel covers. The bumpless 16" Ford wheel looks very similar to the period clip style 16.5" that was optional in '67 and '68. Notice the little bumped up ring just around the base of the hubcap on this period photo of a '68 GMC 3/4 ton with factory issued 16.5" wheels? I don't trust the screws, I will now investigate the possibility of hot riveting the clip to the wheel, just like the factory would do it.
#38 |
Now this thread has me wondering if I should save the clips off 2 warped 17.5 rims before I dispose of them. Are people looking for these?
#39 |
I've been investigating tires for my '66 C20 with lock ring wheels. Seems that radials aren't a good match for this style of wheel (different bead profile) but in bias ply there are several choices available. I think that's the direction I'll have to go to maintain the correct pie crust look with the two piece wheels. Radials sure drive nice but they just don't look the same.
Hey, factorystock. Maybe I missed it but what are you working on? I've tried to reach you off-forum but my PMs never go through.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
#40 |
16s came w my truck when I bought it. They are 3 nub but take the smaller 10.5" dog dish.
Anyone know where these wheels come from?
Figure out what you want--then figure out what you are willing to give up to get it. Last edited by Lou Boffa; 10-09-2013 at 05:30 PM. |
#41 |
