![]() Join Date: Nov 2012
Side marker light surprise...
As strange is this may seem I just recently discovered that my 68 has never had side marker lights . It has the actual reflector devices but there are no lights installed in them . Even though these lights are not required by state law I want them for obvious safety reasons . I ordered a set of the light sockets from LMC but need a schematic to install them properly. Can anyone on here post a really good idiot proof schematic for me ?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
Re: Side marker light surprise...
I would think you should be able to tap into your other front signal harness using good and weather proof connections. ofcourse this would cause them to flash when you use your turn signals. Im not sure if thats the operation your looking for?
#16876
Or tap into the marker light wire for a constant. It should be easy to identify with a wire test light.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
I was considering that but then I looked at the wiring schematic on my 81 C10 and it requires all kinds of power wires that run all sidemarkers together and share common ground wires. I figured that the 68 might like we use a similar setup . I do not want them to flash when I signal . Was it normal for these trucks to not have side marker lights installed in them ?
yes its normal. Im not exactly sure which years had them, im thinking the "newer models" like 71/72 had them? i know the first years did not. You could just tap into each nearest marker light and test with a test light to make sure they stay constant power when you have your signals on. You would have to wire each socket into each corner harness and that should be all. You wouldnt have to worry about running grounds for each one or connecting them all together. You would have to play with one to get it figured out then you would know what to do on all the others. Hope this helps get you started. Seems alot more complicated than what it really is.
RAT1968 '68 Cab/'71 Parts
Make these larger.
If you can't, get the big one from the Forum download or PM me...I can't send a big one using the Forum. Obviously, you don't have to go all the way back to the HL Switch....Just find the right (correct) wire, and, "Tally Ho!"
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Nice Job Mag!
Hey highway by the sea, just checked my stock 68 c10 and wire the side markers the way gm designed them to operate: Headlight switch off, turn signals on/ 4 way flasher the side markers turn on at the same time, headlight switch pulled out, side markers are off when the turn signal lights up, then when the turn signal light turns off the side marker turns on. The lesson here is if wired this way always make sure the front park/turn signal bulbs work properly before repairing the side markers. I believe gm did this to get the attention of people to avoid accidents as alternating lights between side markers flashing and turn signals flashing is really hard not to notice. If you want me to check for sure i can later as i'm tired and going to bed, wife and i have worked on our house for days on end to get ready for winter! Good luck, Brian F.
It's normal for a '68 to be reflector only. My '69 came the same way from the factory, and I think it's cool. If I remember, they started lighting late in the model year of '69. Keep in mind that the reflector only are just that. They reflect when a car's lights shine on them, so it's not like you're a complete sitting duck
Old member
For the 71 model the front side lights flash but the rear do not. Factory.
68 was the first year with side markers reflector's and no lights. 69 was reflectors unless you ordered the truck with the lights. Most trucks didn't have the lights ordered. Later years they were required to have them. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Sep 2012
Ok I just got done doing this exact same thing. Now I did not want my sidemarkers to blink but just wanted to have them on as solid side markers. All you have to do is when you get the pigtails they will have 2 wires. It does not matter which wire you use but all you have to do is tap into the front blinker lights in the grill. Now on the front blinker there is a solid posetive and a blinking posetive, tap into the solid posetive with one pigtail wire and the other goes to ground. On the backs you can do the same exact thing, just tap into the solid side of the rear brake light and the other goes to ground. Mine is done this way and works perfectly, no electrical issue or anything and they are on solid when you pull the headlight switch on. Super easy!
#12 | |
Having both (side marker and turn) on at the same time increases current flow, heat and therefore decreases the durability of the components. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Sep 2005
Fed Hiway Trans Safety Board mandated side reflectors only on 68 model trucks. Did not have to be illuminated until 1969.
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
#14 | |
I knew '69 was the first year for Federally mandated side marker lights for passenger car but wasn't sure about trucks. K
#15 |
It's not quite that simple. Depends on when in' 69 the truck was built. Mine was an early 69 build and doesn't have lit markers. No wiring or evidence of wiring at all
#16 |
Thanks for all the fantastic help with this issue ! I have the front ones hooked up and they work perfectly with the blinking like was described on here. I just wired up the right rear one and I am lacking the wire splices to do the left one tonight . This normally would not have taken so long but I broke my hand recently and I've had to do this mostly one handed .
#17 |
Now I just need to figure out how to keep the rear marker lights from going out when the headlights are on and the brake pedal is engaged . Damn!
#18 |
Good Lord, I know what you're talking about....chasing blinker/brake/parking/dash light gremlins myself.... NEVER fun.
#19 | |
Whenever I ask the electrical guys for help that's always the first thing they say. K
#20 | |
FRONT: One side marker wire to the parking light wire, the other to the turn signal. When you turn the flasher son, no headlights, the ground goes through the parking lights. When you turn your parking lights on, no turn signal, the ground of the side marker goes through the turn signal wire. When you have parking lights on AND turns on, the front turn signal takes the ground away when it flashes, hence the marker goes off... REAR: you need to get one side marker wire tapped into the parink lights, the other needs to go to the ground, so that they only work with the parking lights and have a constant ground. Hope that helped!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
