10-11-2013, 07:32 PM | #1 |
Can my truck haul it??
Well I've been wondering about this for a few weeks. I just got done building a vw rail buggy and it's not street legal so I can't drive it on the road. When I decide to take this thing somewhere I gotta trailer it or tow it with a tow bar. My 69 is my only truck so it's all I can work with for mow. The question is, with my 2500 stall will I burn something up while pulling this 900lb rail with tow bar and 250lb 4 wheeler in the bed? I have plenty of power but I don't wanna mess up my trans or stall trying to tow this stuff down the road. What do you guys think??
Put that hammer down and give it hell! 69' custom/10 longbed. 1999 1500 4x4 5 speed |
10-11-2013, 07:39 PM | #2 |
Re: Can my truck haul it??
you should have no issues, unless you're trying to do it with the inline 6 with 300k miles on it
since you're using a tow bar, not a trailer you're taking that tongue weight off it, so that's nice. I use my truck to carry my 900+lb Harley Electraglide in the bed so you should be good
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
10-11-2013, 07:44 PM | #3 |
If you feel it slipping when towing, don't do it. They make stall converters that retain the ability to tow.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
10-11-2013, 08:53 PM | #4 |
Ok thanks. I figured the tow bar would help but wasn't sure how much. I've never towed anything with my truck before so I was unsure. I need to get a trailer hitch now lol. Are the ones from lmc any good??
10-11-2013, 09:59 PM | #5 |
In Texas, if you flat tow a vehicle, it has to be registered, insured and inspected. If you don't want to do that then it needs to be on a trailer. That's TX law, but I would suspect that CA would be more stringent, not less...
10-11-2013, 10:05 PM | #6 |
First: A stall rating on a converter is somewhat of a misnomer. That 2500 stall may stall @2000 or 3000. This all depends on engine torque. So, a 2500 stall in a worn out L6 may stall at 1500rpm and behind a stout 454 it might stall at 3500. They easiest way to find what your converter is actually stalling at is to power-jack it. Foot on the brakes hard and add power until the wheels start to spin, that is your stall.
So to answer your question, towing with a stall converter will not hurt anything. So long as your cruising speed/rpm is above the stall rating. cruising below the stall rating generates lots of heat and if you cannot manage that heat it will smoke the tranny. Lockup/overdrive trannys are a different story. So what tranny are you running?
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
10-11-2013, 10:28 PM | #7 |
A trans temp gauge and a add on cooler in front will help your situation out a good deal, What rear gear do you have ? did you quote the driving rpm's @55? some of those thing might help us better help you but from what is here in these post already I would say it is pretty much taken care of. Jim
10-12-2013, 01:24 AM | #8 |
I'm running a th350 behind your average SBC build. Its pretty basic .40 over, flat top pistons, comp 270 magnum cam, slightly ported 882 heads, 1.5 roller rockers, weiand dual plane, Holley 600 vac/secondaries. Engine is pretty fresh with about 2500 mi on rebuild. The th350 has been in there since I got the truck 3 years ago. It shifts good and never has it slipped or given me any trouble. I added the stall when I was building the engine because it would work well with the build I was going with. The rear end gears are the stock 3.08. I've never checked to see where the stall fully locks up at. I might have to do a couple burnouts tomorrow and find out haha. As for having the buggy registered in MO to pull it with a tow bar I'm unsure, I'll check into that.
10-12-2013, 07:39 AM | #9 |
The trailer I used was overkill and normally used to haul heavy equipment and my truck pulled it no problem |
10-12-2013, 09:35 AM | #10 |
Registered Cruiser
I towed my buggy on a tow bar a few times. The front end is so light that it makes it a little bit dodgy, so I built a custom trailer for it.
The buggy is so light it shouldn't stress your trans too much. Keep your cruising rpm above the stall speed, and launch easy. Amargosa Dunes Apr.'13 I had the whole place to myself.
I intend to live forever. So far, so good. |
10-12-2013, 12:08 PM | #11 |
Here is my buggy. I never intended for it to match the truck but I thought it would look good in blue lol.
10-12-2013, 12:12 PM | #12 |
Here is another pic while I was putting everything together. It's not the fastest buggy in the world but that ol 1500cc will get you anywhere you need to go.
10-12-2013, 12:49 PM | #13 |
Proprietor of Dale's Corner
In ca you can't tow a non reg vehicle with any of it's tires on the road. It will have to be on a trailer. No tow bar or dolley
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-12-2013, 02:36 PM | #14 |
Well it looks like here in missouri the vehicle being towed doesn't have to be registered. Now I gotta get a trailer hitch and I'll be good to go.
10-12-2013, 07:45 PM | #15 |
Look at some.of the air cooled mags the have a tow bar that will fit on the bugs front beam.most just have two pins to pullout and it drops to the gound.
10-12-2013, 08:51 PM | #16 |
3.08:1 gears you may be pushing the limit. I had 33"tires on my 69 with 3.08's and pulled 2000 @60.
I also had a very (truck/pulling) stout 350 and a 2500 stall that was stalling at about 2300. I rarely only drove 60 and rarely pulled anything at highway speeds. Just my boat that weighs 4k but the ramp was 7 miles away and all country back roads. I also had a large external cooler on it.
10-13-2013, 01:00 PM | #17 |
One thing about towing that a lot of guys don't consider is that there are many other factors besides just "Will it pull it?"
A more important issue is "will it still stop securely and not lose composure doing it?" If you have even a slight pull to the left or right under a hard stop, it will be magnified tenfold with a loaded trailer behind you. Others have mentioned the dreaded "trailer wag" which can be due to improper tongue weight or load balance issues. Having your load secure is important as well, as any load shifting can cause dramatic and sudden changes in handling. Y'all be safe out there!
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
10-13-2013, 04:32 PM | #18 |
Too many projects
I would vote for a small trailer to fit the buggy on. As light as it is, a cheap single axle just big enough for it to fit on would work well. You could leave it on the trailer loaded ready to hookup and go. My biggest worry with flat towing is when you have too much fun with the buggy and break something that would prevent it from being towed back. A flat tire or a fried bearing would keep you from pulling it with tires on the road.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
10-13-2013, 07:31 PM | #19 |
Tow bared one from Nashville to St. Louis in July one year with my 69. 3:08 ratio rear with a stick tranny. Had no difficulties. With a turbo I would think a tranny cooler would be all you need and in dead heat of the summer a good water temp gauge. Heat would be my biggest concern.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
10-14-2013, 12:26 PM | #20 | |
