Old 12-09-2003, 09:44 PM   #1
walker
walker's Avatar
Leaking power steering ram,'67
Is there a rebuild kit, or are the power assist rams available for the '67 power steering units. Mine started leaking at the spot the steering arms ties in to the tie rod. Also, should there be play in that spot? It seems like that is a control valve for the ram, and should move back and forth to work a piston/pistons to allow hydraulic fluid into/out of the ram. Is that how it works in a nutshell?
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 12-10-2003, 12:55 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
No idea where you would get them, but it probably just needs the seals and stuff replaced.
Not too bad of a job really. You could talk to a local hyd repair place and see if they can get you a repacking klit.
Old 12-10-2003, 01:37 AM   #3
Zumo
Hot Rods For Life
Zumo's Avatar
Is that this one?
67-78(?) Corvettes have the same thing and I think they are interchangable and can be ordered new.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 12-10-2003, 02:10 AM   #4
68 Suburban
68 Suburban's Avatar
I think there is a Corvette place out of Justice, IL that sell rebuilt ones for about $80 exchanged.
68 Suburban is offline   Reply With Quote
Old 12-10-2003, 09:26 AM   #5
JJR
JJR's Avatar
I believe GMC Paul has the rebuild kit (other vendors probably have it also). For that matter, Advance Auto parts shows kits and rebuilt units for this stuff also (you will probably need to tell them you have a 70 Corvette instead of a truck). It will be the same parts for a similiar year Corvette. Here is a link to a company that does exchanges for a decent price. http://www.melroset-tops.com/power_steering.htm
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
