#576 |
Re: 1968 Chevrolet SWB Stepside Restomod
Hey all;
I got a late start today but I finished wiring up the fan relay harness. I ran out of electrical tape and I need to buy a couple different sizes of wire loom to wrap it with so I will finish that part tomorrow and put up some pictures. Here are some pictures of the current progress. ![]() ![]() |
#577 |
![]() Join Date: Aug 2012
looks good and good luck with the wiring .
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
#578 |
Hey all;
I finished up the harness today. ![]() |
#579 |
I bet you are glad the wiring is done. I am just starting the wiring this month. I wll be ordering a wiring harness this next week.
#580 |
I still have more wiring to do, exterior lighting, horn, and all interior wiring.
#581 |
Hey all;
Several months ago I purchased a 20 circuit Universal wiring harness from Speedy Bill. Yesterday I finally got around to start planning for the installation. For those of you who like me have never attempted anything of this magnitude before it can seem overwhelming to say the least. The first step in the process was wrapping my head around the big picture and understanding that this is basically the automotive equivillent of the nervous system in the human body then things start to come into perspective. Everything needs power and with that in mind you can break the fuse block down into two catagories, constant power and ignition on power and once you understand that things become much more clear. Constant power consists of things such as Headlights, horn, courtesy lighting, door locks, etc. Ignition on power consists of things such as starter, fuel pump, radiator cooling fan(s), windshield wipers, windows, etc. Another thing to understand about a complete custom wiring harness installation is that this is a marathon not a race, take your time and do it right because you don't want your ride to burn to the ground after you have spent 1000's of hours and 10's of thousands of dollars on it. Here is a list of tools and consumables you will need to complete the installation. 1) Crimper, Linesman pliars, Dikes. 2) Electrical tape, Heat gun, Heat shrink tubing (assortment), Protective wire wrap(Loom), Zip ties, HVAC foil tape. 3) Soldering gun, flux core Solder. 4) Di-Electric grease. 5) Patience and Perseverance. Good wiring practices are important. With that in mind here are a few tips I have picked up, this is not a comprehensive list. 1) Seal every connection because rust and corrosion is not your friend. 2) Use the proper connector. 3) Tag wires for reference. 4) If you have to extend a wire use the proper gauge. 5) Plan ahead and route your wiring with future access in mind. 6) If you are going to route wiring near a high heat source shield it with protective wire wrap and HVAC foil tape. 7) Secure it. Whew that was a lot of typing, ok so hopefully this has been informative and helpfull, I know it's a lot to take in but you will get the hang of it easily enough. Dive in head first. Till next time... Last edited by Xeen; 10-19-2013 at 07:44 AM. |
#582 | |
#583 |
Looking forward to the next few update
#584 |
Nice talking to you today. Remember post plenty of pictures. It helps us guys out. They are a learning aid for us. Good luck and will be watching your build.
#585 |
no update today??????????????
#586 |
The temperatures have been in the 50's reaching the low 60's mid afternoons so I haven't had much desire to be out working on the truck, I hope to get some work done on wednesday.
#587 |
I'd rather be working in the 50's than the 90's with the humidity we had here in the Houston area (not now, but earlier in the year). But that's me...
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#588 | |
Durring the winter work pretty much stops since it is outside so my build just got extended out another 6 months unless we get fortunate enough to have a smattering of nice days tossed in here and there where I can get some pretty significant work done and then I have to force myself to be motivated on the few days of good weather I do get ![]() |
#589 |
OK, so that's different. Good luck with having good weather AND motivation.
#590 |
I understand about the weather. Here in Florida it is hot or it is hot. But today it was really nice around 75 by 1.00 a good day to work on the truck. But I have three fires I have to put out first. Maybe around the first I cn see some day light to work on the truck. My build should be ready to drive around April or May 2014. Good luck with your build and the weather.
#591 |
Hey all;
Don't ya just hate it when you can't find the one thing you need to do an installation. I went out early this afternoon when it warmed up to start installing the 20 circuit wiring harness and I can't find the Junction block I purchased for the job. I checked my receipts and I purchased it but I can't find it....ugh. I'm going to lose the light soon so I guess that's it for the day, it's supposed to be warmer tomorrow so I should be able to start earlier and I might accidentally get something done. On the bright side I checked the fitment of the fan relay harness and it fits really well so I'm happy about that. |
#592 |
did you find the harness block yet? I hope it didn't go to never never land.
#593 |
Hey all;
After watching the Chiefs beat the Browns - Go Chiefs! I continued work on the wiring. I found the junction box in one of my LMC bags, apparently I overlooked it yesterday. Here is my progress so far. I ran the main +12v wire through the firewall. ![]() I installed the junction box, relays for the fans, +12v for the HD headlight harness and the battery to fender ground. ![]() |
#594 |
Hey all;
I continued working on the wiring today, it's slow going. I installed a weather resistant inline fuse holder for the fan harness and connected it to the junction box and connected the ground to the fender. I bolted in the relays for the HD headlight harness and connected the ground for the LH side headlight to the core support. I installed wire wrap on various wires. For the fender ground connection I used a copper washer to ensure good conductivity and some di-electric grease to ensure the bare metal on the fender doesn't rust. I just have a few more small things to do in the engine compartment before it's wrapped up, like finishing up wire wrap on various wires, securing the wiring, installing the horn and running the wiring for the horn, turn signals, parking lights and headlights to the fuse box. ![]() ![]() ![]() Last edited by Xeen; 10-28-2013 at 07:00 PM. |
#595 |
looks fine man can't wait till I am at that stage
#596 |
Hey all;
Wiring progress update. I ran the wiring through the firewall for the headlights, front parking lights, front turn signals, horn, coolant temp and oil pressure. Next up is the wiring for the rear of the truck. |
#597 |
It's like when the monkey got his tail caught in the door. He said it want be long now. Keep up the good work.
#598 |
![]() Join Date: May 2013
You should make a trip to Texas and wire mine. I hate wiring in a bad bad way. Looks like you are making some good progress. Sorry I didn't have much time to talk today. I've been up since 4:30 with the wild maniac kids lol. I'll try to give you a call Monday, I have some questions regarding the cpp trans x-member anyway. I may just run the stock stall for now until I work out the bugs. As long as it won't be a huge pain to drop the trans and swap converters later that is
#599 | |
![]() Call me anytime in the afternoon I will be around. |
#600 |
Hey all;
Wiring progress update. Today I ran the wiring through the firewall for the brake lights, rear turn signals, rear side markers, reverse lights and license plate light. I'm going very slowly to make sure I do this right so it may take awhile to finish. |
Tags |
1968, chevrolet, restomod, stepside, swb |
