#976 |
Still Learning
Re: Project "Just an Old Truck"
Very nice job on the window rebuild. Where did you buy the replacement parts?
#977 | ||
A day late and $1 short...
Thanks, I bought the vent windows from board member rogerkoop, and the rest of it came from GMC Paul.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#978 |
While we were at Cruisin' the Coast the truck had a weird feel to the front end when I applied the brakes and it was pulling a little to the left. Rob (Hart_Rod) said I needed to check the upper control arm shims, but I shrugged it off. I decided to take his advice and I'm glad I did, the left side aft shim pack had fallen out! They were sitting in the top of crossmember. I reinstalled them and torqued all of the upper control arm nuts to 70 ftlbs. I think I'll take it to the alignment shop and have it checked...
#979 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Measure your "final" shim pack height and make a piece of tubing (or round stock shim) to replace it.
That way they can't fall out.
#980 | |
#981 |
Boy I'm glad you got that fixed before something bad happened!
-Rus |
#982 |
Glad I got to meet you at CTC, Buck. The 68 looks even better in person.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#983 | |
#984 |
Glad you avoided disaster! Nothing has fallen off my truck YET, but I'm sure waiting for it, ha ha.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac |
#985 |
When ever we have a car or truck that needs that many shims i replace most of them with flat washers and stagger a couple of shims in between so you can still adjust for the alignment.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
#986 | |
That's a good idea too. The funny thing is; after the new alignment I don't have nearly as many shims. I guess the first shop isn't very knowledgeable about dropped suspensions, drives much better now!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 05-09-2016 at 12:33 AM. |
#987 |
Little prelude to an update... Ordered a Circle D torque converter with a 2600-2800 stall speed today. After talking with a few guys who have LS swaps with aftermarket cam upgrades I learned that having a looser converter will help with the low idle and "pushing" in gear. We'll see in a week or so... I wonder if my transmission will come out without having to dismantle the truck?
#988 |
Very nice truck!! The patina is perfect!! I'm planning on an LS swap in my 69 gmc swb fleet side. Looking forward to your progress..
#989 | |
The converter has been swapped and the cooling lines have been reconfigured to use the cooler in the radiator and a heat sink style cooler. Still need to change the filter and service it up, should have it buttoned up before tomorrow. ![]()
#990 |
![]() Join Date: Dec 2006
Nice, hope the new converter works out for you. We are going to need to see some burnout videos
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#991 | |
#992 |
Well it took me a few days, but I've read your entire thread. Truck looks great and I love everything you've done. A few hours of reading and 40 pages later, you are now responsible for me spending more money on my truck and lengthening my build.
I really like those wheels btw. Those were the ones I originally wanted until I scored a deal on my 18" Ridlers as a temporary wheel. Next you need to do the PB coilover kit as that's what I'm looking at. I'm interested in hearing the difference in ride and handling ![]()
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#993 |
The converter swap is complete and I am happy to report it went well. I was worried it would be a task given all the changes that have been made to the chassis, but it was very simple. I didn't even have to remove the exhaust! The converter has woken up the engine quite a bit by allowing it to get into the power band immediately and the pushing and idling issues have subsided. I also picked up a set of NOS outer rockers from GMCPAUL, so when I do get started on the body I'll have good parts to start with.
#994 |
Tot Roddin'
Body work... Say what???
I'd roll that thing just the way it is.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#995 |
Junior Member
Kinda shocked to hear you might paint this rig.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#996 |
No paint!!! lol I'm glad the converter fixed your issues
-Rus |
#997 |
Great news about the converter, glad it fixed your problems
#998 | |
![]() Thanks bro, is a big relief!
#999 |
I feel ya Bucks68!! My hands tremble when I hear the same statement!! The other dumb statement is "now all you need is paint"... If I had a dollar for every time I heard that, I'd be a very wealthy man!!! Hold on to the patina as long as you can..
#1000 |
