Old 10-14-2013, 10:23 AM   #1
Crash_OK
Crash_OK's Avatar
Crash's Roof over Lake House Build
Warning.. Like my 69 K10 build this Thread will contain lots of pictures..
While I am waiting on finding a 1st gen Camaro to build I decide to take on a project that I have been attempting to have completed for the last 2 years (I have had 4 different contractors commit to it, but never showed for one reason or the other). I have a little place on Lake Eufaula in eastern Oklahoma. It has two really nice decks on the back of my mobile home. The problem is in the summers it is too hot to sit on the decks due to no shade and in the spring and fall if it is raining you are out of luck as well. I decided I wanted to cover both decks but did not want to attach the cover to the mobile home in any way. So below is the idea that I came up with. This also help in other areas, like cooling, roof repair, etc..
Model without the metal…
Motel of mobile home only..
All the modeling was done in Google SketchUp.
Below are the before construction pictures.
First delivery of lumber and concrete. ~3000 worth… The 6x6 and 5x5 post were over a third of that cost.
First step was tearing down one of the old decks in the rear and start installing the post that will support the deck.
When I got ready to set the post on the larger deck I found a 2x10 that was used to support the deck was broken. Had to repair that before I started the post install.
Set both corner posts after deck repair.
All four corners on main deck set..
On one of the corner post there was a slab of concrete 16” thick that was used as a runner to support the mobile home. I did not want to jack hammer it out so I drilled a hole in the slab and in the end of the post and installed a 30” piece of ˝” steel rod to tie the two together.
Sitting the four inner post were the hardest, tough to dig, lots of crawling around, just hard to get to..
Next step was sitting the rest of the post in the back.. two on the east end..
Then the three in the smaller rear deck.
And then the two on the west end..
Integrating the post into the existing decks was very time consuming and required a great deal of work. But in the end it made the decks stronger and helped tie the post together in the back.
Next step was the front.. Also removed the old red paint front deck to install the new post.. I will be rebuild the front, making it larger..
After that it was time to build the front deck..
I was also able to borrow some scaffolding from a friend of mine… Thanks a lot David…
And also a deck in the back to replace the old one I tore out..
So far I have ~68 hours in the construction across 9 days.. 3 weekends and a couple of days of vacation. .. I hope to take off a couple of days this week as well, so maybe I will have some more progress to show soon.
The next step is the finish putting the decks back together and finish up on the deck railing. After that I will start the process of cutting the post to the proper height and notching each of the post for the doubled up 2x8 headers..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 10-14-2013, 10:59 AM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's Roof over Lake House Build
Only 68 hours? Clearly you aren't a beer drinker.
That's one heckuva project Mark!
Zoomin is offline   Reply With Quote
Old 10-14-2013, 11:00 AM   #3
Crash_OK
Crash_OK's Avatar
Thanks Steve.. I drink them fast...
Mark
Crash's 69 4x4 SWB
Old 10-14-2013, 11:11 AM   #4
mcbassin
Still Learning
mcbassin's Avatar
Nice work Mark. You made good use of your time instead of watching the whole OU fiasco like me.
Let me know what your plans are for Saturday, if I can break free I will come lend a hand in the consumption and supervision department
Old 10-14-2013, 11:16 AM   #5
Crash_OK
Crash_OK's Avatar
Thanks Mike.. I stopped watching in the 2nd quarter and had lots of beer afterwards..
Not sure what I will be doing Saturday, but you are welcome to come on down.. I am sure I will be working on something..
Mark
Crash's 69 4x4 SWB
Old 10-15-2013, 06:32 PM   #6
chevyrestoguy
chevyrestoguy's Avatar
I love home construction projects!! I really like the idea you're going with, too.
I can't imagine how many of your neighbors have dropped by and asked what all the 6x6 uprights were for. Just tell them that you're building an above ground pool with a basement.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 10-16-2013, 06:48 AM   #7
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
The ONLY way to "re-roof" a single-wide. Looks great, I gotta say, I kinda dig your patio.
screamin_c10 is offline   Reply With Quote
Old 10-18-2013, 02:05 PM   #8
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Fantastic project that will hopefully add lots of comfort and enjoyment to your home. I bet it will be quieter and lots more cool in the summer months inside as well..
Good work!
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 10-21-2013, 09:02 AM   #9
Crash_OK
Crash_OK's Avatar
Update time.. Finished the deck, deck railing.. I hate balusters.. Set the last posts.. cut and notched the post to length… Installed the headers.. McBassin spent the all day Saturday helping me.. thanks Mike. I also installed all the top plates..
Next step is the short wall that fits on top of the headers..
Mark
Crash's 69 4x4 SWB
Old 10-21-2013, 09:15 AM   #10
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress Mark! You had a busy day yesterday. Hope to get back down there in the near future. Thanks for the hospitality! you know how to feed a guest
Old 10-21-2013, 11:35 AM   #11
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You hate balusters? I hate digging post holes and setting posts, mixing concrete. It's looking fantastic - great improvement.
Old 10-21-2013, 01:19 PM   #12
Low Elco
Great iimprovement! Really nice!
Low Elco is offline   Reply With Quote
Old 10-24-2013, 04:52 PM   #13
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Very cool project. Got me to thinking about high school summers 100 years ago. I'd go camp/ski at Belle Starr for 10 days every year.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 10-27-2013, 07:36 PM   #14
Crash_OK
Crash_OK's Avatar
Another good weekend of progress.. got the short wall up and now we are Ready for Trusses…
Next step… Trusses I hope
Mark
Crash's 69 4x4 SWB
Old 10-28-2013, 08:19 AM   #15
mcbassin
Still Learning
mcbassin's Avatar
You made great progress Mark. When you planning on getting the trusses delivered?
Old 10-28-2013, 08:37 AM   #16
Crash_OK
Crash_OK's Avatar
Not sure.. Ordering them today...
Mark
Crash's 69 4x4 SWB
Old 10-28-2013, 08:47 AM   #17
Clyde65
Clyde65's Avatar
So.....When is the party mark?????
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-28-2013, 08:55 AM   #18
Crash_OK
Crash_OK's Avatar
Truss installation party???
Mark
Crash's 69 4x4 SWB
Old 10-28-2013, 02:46 PM   #19
Clyde65
Clyde65's Avatar
Man if I could I certainly would come and help out. Long drive, family in hospital and stupid boss wants me to work...can you believe that??
Clyde65
Rebuild of Clyde
support our troops!
Old 11-08-2013, 07:27 PM   #20
Crash_OK
Crash_OK's Avatar
Last weekend’s progress.. Built the steps and platforms to get on the decks.. and cleaned up the area around the house while I waited on the Trusses..
Mark
Crash's 69 4x4 SWB
Old 11-08-2013, 08:26 PM   #21
Crash_OK
Crash_OK's Avatar
Received the Trusses today.. Decided to see if I could get them on the top by myself. My wife helped by hooking the rope up to the trusses on the ground saving me a lot of ladder climbing.
Success.. Ready for tomorrow, my son and a good friend are coming over to help me set the trusses…
Mark
Crash's 69 4x4 SWB
Old 11-09-2013, 01:45 AM   #22
mcbassin
Still Learning
mcbassin's Avatar
You made that look too easy
Old 11-10-2013, 09:15 PM   #23
Crash_OK
Crash_OK's Avatar
Thanks Mike :-)
Mark
Crash's 69 4x4 SWB
Old 11-10-2013, 09:35 PM   #24
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Did you get the trusses set today? Great weather for getting stuff done.
Old 11-10-2013, 09:48 PM   #25
Crash_OK
Crash_OK's Avatar
You bet... I had a friend from work come help Saturday morning, and then my oldest son and I worked in to the night.. I finished up today..
Mark
Crash's 69 4x4 SWB
