Old 10-14-2013, 12:53 PM   #1
jorgensensc
jorgensensc's Avatar
At the dyno!!!
Here she is on the dyno at Cunningham Motor Sports! Hopefully they can get the tune working right! Can't wait for it to be done!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-14-2013, 02:01 PM   #2
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: At the dyno!!!
Looking forward to hearing how she does.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 10-14-2013, 05:36 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: At the dyno!!!
Cool... make sure u post the out come!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-14-2013, 08:15 PM   #4
jorgensensc
Re: At the dyno!!!
Arghhhhhh!!!!! Well, did the tune. Ryne worked hard on it. I'm not too thrilled with the numbers, 300 torque and 302 horsepower at the wheels. Seems to be about a 25% loss through the drivetrain. Ryne said something about heavy drivetrain and only getting into 2nd gear because of the 3.54 rear. It has the Dana 60 rear. He reminded me that these are just numbers.
Seat of the pants says something completely different. It is very quick and feels a lot faster than that.
Now comes the really frustrating part. So as I'm driving it around before I head back on the 1 hour and 45 minute drive, I get on the freeway and go wot at around 75 mph. She goes into limp mode on me. I get it back to the shop and he pulls up the code P0606. Internal PCM performance issue. I have pulled this code before I took it to him. He says that there is some problem with the PCM. He is going to try and get another one for me and will program it for free. Just may take a few days. In the meantime, I just can't romp on it on the freeway at speed. From a standstill it seems ok. He said it will randomly happen. So I've got my scantool hooked up so that when it happens I can clear the code without stopping on the side of the road. Sucks when it goes limp in the middle of the freeway doing 70! Somebody tell me something good, please! I'm feeling pretty discouraged right now. My old big block wouldn't be giving me these problems!
Shawn
Old 10-14-2013, 08:25 PM   #5
mud.man.rj
mud.man.rj's Avatar
Re: At the dyno!!!
20-25% loss threw the drivetrain seems quite common, so just add the extra lost for a #, as for the other problem, who knows with modern electronic's, sure you will get it worked out, may even give you more power if the problem was substancial enough. We will be all ears when you get it straightened out. Good luck. Rick/Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 10-15-2013, 11:47 AM   #6
jorgensensc
Re: At the dyno!!!
Thanks for the kind words. It also didn't help that the 91 octane that I just filled the tank with was bad gas. When he tried to tune it on 91 in the ECM it knocked like crazy. He had to pull timing to get it to stop. Hopefully he will be able to get an ECM for me.
Old 10-15-2013, 12:01 PM   #7
Hart_Rod
Hart_Rod's Avatar
Re: At the dyno!!!
That suxs. Hopefully he will get it straightened out.
Hart_Rod is offline   Reply With Quote
Old 10-15-2013, 12:48 PM   #8
jorgensensc
Re: At the dyno!!!
Thanks hart! I think he will. He has a good rep and seems to be a stand up guy. I just hope that my old daily driver is as important to him as all of the other amazing cars that are in there. Did I mention that he had this there also:
Old 10-15-2013, 10:48 PM   #9
rcrahn
rcrahn's Avatar
Re: At the dyno!!!
I've been reading your posts and know that you have been on a rollercoaster ride. At this point you seem to be on the right track. Working with a reputable tuner is the right move. This can and will eventually get sorted out. I appreciate how you have taken the time to post your experiences so all can learn.
Hang in there and remember - it's just a machine and there's nothing that cannot be resolved - given enough time and money. Later in life that time and money is transformed into precious gems - experience.
rcrahn is offline   Reply With Quote
Old 10-15-2013, 11:34 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: At the dyno!!!
what are your motor specs again?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
