07-29-2013, 06:31 PM | #26 |
Re: Stock speaker
Here's what I ended up doing.My 69 Blazer did not have any speaker grille in the upper dash. After reading through this post I to believe that there were Blazers built with the speaker grille in the upper dash. There are just too many guys that say they have the grilles in the upper dash and it not to be a factory installation. Just my opinion
07-29-2013, 08:46 PM | #27 |
Re: Stock speaker
Asolde, the way you mounted yours is correct for 1969. Mine '69 was the same way.
Posted via Mobile Device |
07-29-2013, 08:56 PM | #28 | |
Carpe manana
Re: Stock speaker
07-29-2013, 09:39 PM | #29 |
Re: Stock speaker
LOL LOL what a topic to mix things up I heard that some Blazer had the speaker behind the drivers door in the panels . JUST PUTTING THAT OUT
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
07-30-2013, 11:42 PM | #30 |
Carpe manana
Re: Stock speaker
Sorry but now I'm confused and just when I thought we figured this out. I came across this pic from this thread of a 72 CST with a seemingly untouched "survivor" interior and note the position of the underdash speaker relative to the AC controls - the brackets shown must lack the nutserts:http://67-72chevytrucks.com/vboard/s...d.php?t=143007
07-31-2013, 06:29 AM | #31 |
72 K/5 Junkie
Re: Stock speaker
My 72 CST is like the above pic. The interior was also untouched when I took ownership of the vehicle.
08-01-2013, 04:45 AM | #32 |
Re: Stock speaker
My '72 didn't have a speaker in it when I got it, but there are no holes in the dash to mount it off center like some in this thread, but there a tee marks where it could have been bolted with the screws that hold in the A/C controls.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-18-2013, 01:18 PM | #33 |
Carpe manana
Re: Stock speaker
Here's another speaker mounted in-line with the A/C control screws....truck relatively unmolested on ebay at moment
08-18-2013, 02:51 PM | #34 |
Re: Stock speaker
Just took my speaker out of my unmolested 72, it sat directly under the heater controls and the two bolts actually held in my controls. I did locate in the 1972 shop manual that the correct location for the speaker is under the controls (not the dash) My 69 was offset to the left of the heater controls (also non a/c)
08-18-2013, 03:02 PM | #35 | |
Carpe manana
Re: Stock speaker
08-31-2013, 09:35 PM | #36 |
Carpe manana
Re: Stock speaker
Beating a dead horse here but here's a pic of speaker brackets that lack nutserts but appear OEM - for an A/C truck??
09-01-2013, 09:14 AM | #37 |
Re: Stock speaker
I believe that there were two different ways to mount them. My truck is a 69 without air conditioning. I see alot of trucks with air conditioning with the speaker mounted in the center with the bracket outside the dash panel and no nuts welded to them. My truck did not have the speaker installed when I bought it. I put it together and believe I have it correct for my truck. I did not drill any holes the existing holes were correct spacing. The spacing under the air cond contoler is correct too. The bracket with nuts welded to them fits up behind the dash panel and will not work with the ac controler. Anyways I think if you have a blazer with aircondtioning I would be looking at the center type mounting system. I am no expert and really do not know I just went by all the informaition here and the web for my blazer. Good luck
09-08-2013, 12:40 PM | #38 |
Re: Stock speaker
Just bought a few weeks ago a stock speaker from a member and it's from a 69 Blazer with the nutserts in the brackets. My Blazer is 72 and the speaker brackets does not match with the holes on the left side of the dash. It only matches under the heater controls. It's a factory A/C Blazer. Obviously I can't install the nutsert brackets on the bottom of the heater controls. Or can it?
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
09-08-2013, 01:30 PM | #39 |
Carpe manana
Re: Stock speaker
Proof pic that shows OEM brackets that lack nutserts. Luis you can 1) grind off nutsets and mount w AC controller 2) drill new holes or 3) trade for brackets that lack nutserts
09-09-2013, 12:34 AM | #40 |
Re: Stock speaker
Thanks Pete. I will first try and trade the nutserted brackets for the plain one's like the one above. The speaker itself is very clean. Very nice uncut wire.
10-14-2013, 07:08 PM | #41 |
Re: Stock speaker
I found this in my 1972 10-30 series truck service manual.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
10-14-2013, 09:27 PM | #42 |
Carpe manana
Re: Stock speaker
That's helpful!
