Old 10-19-2013, 01:00 PM   #1
SACRAMENTO 71
SACRAMENTO 71's Avatar
Brake issue.... Requesting input from you
Good morning Everyone, hope the weekend is going well so far
Have a situation for you, and would REALLY appreciate as much input or advise as possible.
Truck Info: 1971 Blazer, Disc/Drum set up. All Stock axels
Recent Project: Checked rear brakes and noticed they need refreshing. So I installed new rear hardware (springs, clips, etc) new wheel cyls on both sides, had the drums mechined, and put new pads. Everything went great and I noticed a huge difference.
One week after the completion of the rear brakes project, i noticed that the truck felt sluggish on my way home ONLY, not in the mornings! The following day it got so bad that in traffic I did not need to use the brakes!! The truck would stop by it self!!!
Checked from brakes and the front left caliber was stuck/locked. So I bought new calibers, pads, turned rotors and completely flushed the system. Worked great for a few days and then on my way home from work i noticed that only my front brakes were working..............
So to sum it up, did the rear brakes, then the fronts started sticking. Fixed the fronts and lost all rear brakes????
Any ideas were to start????? PPV's? Master? Booster?
THANK YOU SO MUCH FOR YOUR HELP!!!! I always appreciate the time I get from all your responses! Nick
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 10-20-2013, 08:35 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Brake issue.... Requesting input from you
I would replace the three rubber hoses, and master. Seems like a strange problem to arise after the work you did, but what do you have to lose...rockauto, shame you have 6" lift, cause i have new front hoses for ya
You might want to check your rear brake shoe adjusters, maybe they tightened up
Also, check and make sure the valve in the pv didnt shift as you were bleeding brakes. Is your brake light on....
JMHO, but it seems the problem is pointing towards the PV
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-20-2013, 09:20 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
You might want to post this in the regular truck section for mor views. I have to tell you, I got nothin'. Very odd.
Tom Vogel is offline   Reply With Quote
Old 10-20-2013, 11:36 AM   #4
Special-Ed
Special-Ed's Avatar
sounds like a flaky 40 yr old proprtioning valve and or a flaky master...
it this point i would replace everything that is original.... because its ready for failure anyways
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
