Old 10-10-2010, 08:55 PM   #1
DBear
DBear's Avatar
What the Heck are these???
this is my '71 burb, and at the rear on the driver's side, past the filler neck area are these three hoses/hardlines going into the side underneath. What the heck are these and what do the do?
DBear is offline   Reply With Quote
Old 10-10-2010, 09:24 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: What the Heck are these???
vent lines for smog I believe.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-11-2010, 12:35 AM   #3
mosesburb
I had a V-8
mosesburb's Avatar
They are for the vapor recovery system. One line should go toward the front and end at the charcoal canister. It separates liquid and vapor.
You will not use it with a diesel. A diesel tank is vented with a fitting just like a differential uses (like the ones I used on the vent lines that end up on my firewall).
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 10-19-2013, 03:43 AM   #4
THE DRIVER
If I am removing all the smog stuff from the Burb, do I still need these? If, not what is safe to remove?
THE DRIVER is offline   Reply With Quote
Old 10-19-2013, 07:08 AM   #5
Bigdav160
Bigdav160's Avatar
No and Yes
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-19-2013, 08:50 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I think Bigdav misread your last question. You can remove it all and plug the extra outlets but you will have to be sure and use a vented gas cap or your engine will die after driving a block or so.
Edit: After thinking about it for a few minutes I think one of those lines comes back up to the top of the filler tube as a vent so that the gas doesn't "Burp" back out as you are filling the tank. If so I would leave that one....
LockDoc
Leon
Old 10-19-2013, 10:43 PM   #7
franken
Emission reducing parts have a negative connotation and the to remove desire them is common. Some bits do no harm (to performance) and others are beneficial.
So, if a smog bit does no harm and reduce emissions, why remove them?
PCV (which is actually a benefit) and the charcoal canister are a pair of things that should be kept...
Old 10-20-2013, 12:12 AM   #8
LockDoc
LockDoc's Avatar
I have found that 90% of the charcoal canisters found on these trucks today are inoperable. After 40 years of neglect the charcoal in the canisters is a solid mass instead of granules, in which case would be of no benefit. If you remove the canister and shake it you should hear a rattle type sound... no rattle= no good. There was a thread on here a year or so ago and I think one of the posters found a source for a canister that would work on our trucks or the charcoal granules to refill them. A search might turn up the thread.
LockDoc
Leon
Old 10-22-2013, 06:50 PM   #9
68 TT
Still plays with trucks
68 TT's Avatar
Same goes for the EGR valves. When functional they will let you run more timing and make the engine more efficient but many are inoperative after 40+ years.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
