10-21-2013, 06:34 PM | #26 |
Re: Help me build a Raptor killer
If you are still in the research phase you are a long way off from finding out about pinion angles, no offense. You need to know actual suspension height, and have engine and transmission installed with mounts before you can get an idea of pinion angle. If I were you, I'd drop the "raptor killer" idea and go with a nice reliable truck. Once you insert that phrase you put a lot of pressure on your build and we gear our answers according to what is better than a raptor-not equal. The word killer suggests a vehicle far superior in every way in my mind.
10-21-2013, 06:35 PM | #27 |
Sounds like your not trying to build a raptor killer. Raptor killer would imply long travel, high speed off road shenanigans.
Sounds like your looking to build a nice lifted truck with nice fit and finish and plush ride. I'd shoot over to pirate 4x4. |
10-21-2013, 06:54 PM | #28 |
Ok, this clears things up a little.... Your OP lead me (at least) in thinking you where wanting a desert runner/stadium truck that you planned to beat the crap out of.
I can't speak to the 4x4 part as that is not my interest or forte, but I do know engines. IMHO: there are better ways to make 500hp than the 427Rat, but it certainly is a great way to do it. I think a big block is a lot of extra weight on the front axle, but it is your truck and I respect that. Good luck and enjoy pre-retirement planning.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
10-21-2013, 07:48 PM | #29 |
After coming to understand your situation some more I think the best thing that you can do is first find the shop that is going to build the truck and seek the opinion of a professional.
You completely specing out a vehicle based on the opinion of different people on the internet is a bad idea. You want this to be new vehicle quality and imo the entire key to a perfectly functioning and reliable vehicle is that the sum of the parts add up to much greater than their own merit. In other words, the best parts in the world, if mismatched will be no better than properly matched mediocre parts. This one internet thread cannot supply you with near enough information to make a good decision, and taking ideas from totally different people and mixing them together will also end in failure. As a novice you would need to spend a couple months researching this to understand it enough to get a good idea of what you need. A better idea would be as follows: Ask around on here for recommendations on good local shops. Pick a couple of them and call them with your plans and see what they say. Then post the results back here and we can help you sort through them. and to answer your questions. semi-float axles are used more in half-ton applications. they are relatively weaker than full float, can be harder to replace parts on quickly, but they are lighter. Full float have the additional advantage of putting no weight on the axle shaft itself. In the end the choice comes down to the tire size and intended use. You can make a 10bolt strong enough for this application. the weak link on the 10b front diffs is the axle joints and axle shafts themselves. there are aftermarket HD replacements, but they cost as much as replacing the axle with a D60. as far as 14bff vs D60 rear. It really doesn't matter. the 14bolt is cheaper and easier to find, but a D60, D70, F0rd 9" or Eaton H052 would also work just fine.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
10-21-2013, 09:01 PM | #30 |
So to make a 10bolt strong enough it would cost as much as a Dana 60? Thus the only advantage of the 10 bolt would be weight savings? If so how much weight difference is there between a 10bolt and a Dana 60? I'm assuming just based on size alone it will be more than 100 lbs? Also do they make 8 lug axel shafts for the 10 bolt?
10-22-2013, 12:22 AM | #31 |
Vintage 4x4s
You may want to just find a 01+ up 2500hd with a bad body and swap a body on it. You could go dmax/ally or built 6.0/4l80e and get the superior handling, ride, and reliability, economy, but with the old truck appearance. Would probably be cheapest in the long run and easier to get parts for.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
10-22-2013, 08:28 AM | #32 |
This would be a good place to get ideas for a "Raptor killer".
http://camburg.com/home/ |
10-22-2013, 11:14 AM | #33 |
how about an sm465?
10-22-2013, 11:34 AM | #34 |
Ok I just looked up the weight of the GM crate 427 and it's listed at 520 lbs. The next closest in terms of hp small block competitor is the ZZ383 which weighs in at 397 lbs.
Will 123lbs on the front end make a huge difference in ride and handling? And how much better gas mileage would you get with the 383 vs. the 427? |
10-22-2013, 02:02 PM | #35 |
Jim,
I know you are thinking 4x4, but with an open mind, read this thread, it may be an easy route to more of what you want: http://67-72chevytrucks.com/vboard/s...d.php?t=282398 You really need a modern independent front suspension to make it handle like anything other than old truck, and that alone is going to cost you at least half of your budget. If in the end what you want is a truck that go barreling down unimproved roads and get sideways in the turns a prerunner setup may be your ticket. |
10-22-2013, 07:05 PM | #36 |
Do any of you guys have any experience with any of the 4 suspension shops mentioned in this thread?
http://www.mcneilracinginc.com/ http://www.dixonbrosracing.com/ http://camburg.com/home http://offroaddesign.com/ My main question would be do these guys just do suspension or do they also do complete builds? And out of these 4 shops which one is best to deal with? |
10-22-2013, 09:02 PM | #37 | |
10-22-2013, 11:27 PM | #38 |
Vintage 4x4s
theres a guy on this forum doing it on a Tahoe or suburban chassis and I've seen a 67-72 chevy body on a ram cummins chassis also. I'm tempted to do with a longhorn sometime, since it has the same wheelbase as a newer chevy regular cab lwb.
10-23-2013, 07:40 PM | #39 |
Anybody got any recommendations for shops that specialize in complete frame off restorations of classic 4x4's?
10-23-2013, 08:41 PM | #40 |
Vintage 4x4s
PM deadheadNM here, he just recently had his K20 done in NM and it turned out great!
10-23-2013, 08:43 PM | #41 |
GV only works in 2wd.
Gm doesn't make 10 bolt front axles. LS platforms are not "the" set-up LS motors are the latest cheap salvage/decent hp motor. The LS is not more reliable than a SBC or BBC, period. 700R4 can be built to handle 500+ hp A Raptor style fender is required for the suspension travel vs rediculously tall body height. Not sure why in the past 5 years or so all the internet jockeys on forums preach that carb motors/non-LS motors are unreliable. Not sure where this is coming from. The biggest challenge is the suspension which for what your expectations are, you are going to have to get it engineered/designed by a offload shop like in Arizona/southern California. Lots of trophy truck/buggy shops but you will pay dearly for it to work as well as a Raptor. I have both a C10 SWB (2wd) & a 2010 Raptor w/6.2L. I wouldn't want to try and make an old truck handle like the Raptor, just too much cash for the design effort associated its king a truck be balanced & handle well. You could run it like an old 70s baja truck would have been with really good shocks & longer travel good springs but not what a Raptor is capable of. Last edited by grancuda; 10-23-2013 at 09:07 PM. |
10-23-2013, 09:07 PM | #42 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=528308 |
10-23-2013, 09:14 PM | #43 | |
10-23-2013, 09:51 PM | #44 | |
Vintage 4x4s
Correct, that is his build thread.
See below Quote:
I suppose you could swap in a newer chevy IFS without any sheetmetal mods but it would probably be harder than the body swap Idea I mentioned.
10-24-2013, 12:22 PM | #45 | |
Here's a link to the full version It's kind of long but it’s a cool build. There are some shorter clips of this build in the related videos section. Anyways in one of the vids he mentions that "the quick ratio steering" really makes a huge difference but he did not elaborate much at least not that I can remember. I was planning on watching again to see if I could get more info about it. Anyways the reason I'm curious about the steering is I remember back in the day on all my old vehicles that had power steering they were always 1 finger power steering. Not really what I would call a modern high performance feel. |
10-24-2013, 02:16 PM | #46 | |
I want to do what he did except I want my build to lean a little more to the performance side instead of the concorus/NOS side. However I still want the body and cab to be as factory original as possible. |
10-25-2013, 07:05 AM | #47 |
Buy a brand new frame and chassis with a nice clean ls motor, swap the body onto it. 50k buys a lot. With a warranty.
10-25-2013, 07:59 AM | #48 | |
10-25-2013, 09:25 AM | #49 |
[quote=grancuda;6330001]GV only works in 2wd.
Gm doesn't make 10 bolt front axles. LS platforms are not "the" set-up LS motors are the latest cheap salvage/decent hp motor. The LS is not more reliable than a SBC or BBC, period. 700R4 can be built to handle 500+ hp A Raptor style fender is required for the suspension travel vs rediculously tall body height. Not sure why in the past 5 years or so all the internet jockeys on forums preach that carb motors/non-LS motors are unreliable. Not sure where this is coming from. I have both a C10 SWB (2wd) & a 2010 Raptor w/6.2L.[/quote It's bad taste you'd insult anyone on this board calling them an internet jockey.It doesn't matter if it's one post or 10,000 on here. You don't know anyone or their background. Insulting opinions drag this board down. Last edited by leftybass209; 10-25-2013 at 09:35 AM. Reason: changed from argumentative to informative |
10-25-2013, 03:39 PM | #50 |
Let me ask you guys this. Originally I was planning on trying to locate a 3/4 ton long bed truck that had leaf springs. But now I'm wondering if I might be better off to use a 1/2 long bed with rear coil springs. Would you get more suspension travel with the coil spring truck? And are there parts out there to beef up a rear coil spring suspension?
